Old 10-31-2012, 12:26 PM   #1
Kurenai
Drives: 2013 Scion FR-S Hot Lava 6AT
Grinding / Shaking under emergency braking
So on Sunday, I was nearly hit by someone who just randomly decided to merge into my lane, but I wasn't hit due to judicious application of the brakes. However during said braking, the pedal starting severely shaking and I hear what I can only describe as grinding.
Under normal braking, I have never heard anything like this (~6300 miles). I was able to replicate this today buy accelerating to ~20mph in a parking lot then immediately applying the brakes hard.
Is this the ABS/booster system kicking in.. or something else?
Kurenai is offline   Reply With Quote
Old 10-31-2012, 12:29 PM   #2
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
this is how ABS feels like
working as intended
Old 10-31-2012, 12:37 PM   #3
Kurenai
working as intended
I'm hoping that's true, but the ABS on my MR2-Spyder wasn't nearly this aggressive/loud.
Old 10-31-2012, 12:54 PM   #4
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
okay you got me, i lied, you have a catastrophic defect in your car, you should go to a Ford dealer immediately to have this looked at.
Old 10-31-2012, 01:13 PM   #5
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
Sounds like ABS to me.
- The Ancient BRZ Sacrament
by Zaku
Old 10-31-2012, 01:25 PM   #6
jstn
Drives: '15 Vortech Supercharged
Just ABS getting rowdy. Some cars aren't as violent about it as this one.
jstn is offline   Reply With Quote
Old 10-31-2012, 01:26 PM   #7
jadewbj
jadewbj's Avatar
Drives: 2013 Whiteout Scion FRS
This sure sounds like ABS.
jadewbj is offline   Reply With Quote
Old 10-31-2012, 01:58 PM   #8
canu_50
canu_50's Avatar
Drives: Scion fr-s
problem solver? take out abs fuse
canu_50 is offline   Reply With Quote
Old 10-31-2012, 03:36 PM   #9
mhigham
ABS, sounds normal. Likely had some stability control, ABS based, also being applied. These systems pump very fast now compared to older systems for better control and less locking of the brakes. I havent had mine come on yet except for stability control, and its loud.
[ame="http://www.youtube.com/watch?v=dj7WIlliwgQ"]Subaru BRZ drift secrets, stability control, VSC and TRC settings - YouTube[/ame] good video and you can hear the system going nuts.
Mike
mhigham is offline   Reply With Quote
Old 10-31-2012, 04:26 PM   #10
wheelhaus
wheelhaus's Avatar
Definitely sounds like ABS. The ABS pump makes a grinding sound as it cycles on and off dozens of times per second. I've driven many cars with ABS, some were smoother, but you can still hear and feel the ABS when it was active, especially under you foot.
wheelhaus is offline   Reply With Quote
Old 10-31-2012, 04:32 PM   #11
Spartan65
USMC Veteran Semper Fi
Spartan65's Avatar
Drives: 2010 WR Blue STi
In reference to shaking , is anyone experiencing shaking when turning off their car?
Spartan65 is offline   Reply With Quote
Old 10-31-2012, 04:39 PM   #12
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
yes, this is normal in vehicles with moving components like an engine, transmission and other pieces with mass that move around.
FWD drivers may tend to experience this less than awd/rwd cars.
Old 11-01-2012, 10:32 AM   #13
wheelhaus
wheelhaus's Avatar
Yes it's normal. When the engine is running it vibrates, at all RPM, but when it slows below idle the vibes become much lower frequency and more pronounced. The engine shakes a lot more because it can't balance itself well. Same thing happens when you start the engine.
Old 11-01-2012, 10:47 AM   #14
rick
rick's Avatar
Drives: 86
ABS
rick is offline   Reply With Quote
Bad Emergency Jack? JDMenrique Issues | Warranty | Recalls / TSB 35 11-27-2015 07:55 PM
notchy/gritty transmission. every gear grinding prest1ge Engine, Exhaust, Transmission 41 12-09-2012 06:45 PM
Severe Shaking while in Idle from 0-5 mph ScionFR-S Engine, Exhaust, Transmission 1 10-15-2012 09:42 PM
Slight grinding from the brakes... kndonlee Other Vehicles & General Automotive Discussions 7 09-15-2012 05:14 PM
Manual grinding sound deedz Engine, Exhaust, Transmission 22 07-20-2012 10:05 PM
