Old 04-18-2013, 03:58 PM   #1
was385
Drives: MT WRB BRZ Limited, 2007 911s
Aftermarket camber bolts safe?
I ordered the SPC camber bolts and while talking with a performance shop around me about doing the alignment (told them to just throw the bolts on while they're doing it), I was told that they don't suggest aftermarket camber bolts (and will not install them) because they've seen too many instances of them snapping. Does anyone have any experience with this? I was told they can do another modification to get 1.25-2 degrees of extra camber.
was385 is offline   Reply With Quote
Old 04-18-2013, 04:01 PM   #2
wootwoot
Drives: FRS
What is their "other modification?"
wootwoot is offline   Reply With Quote
Old 04-18-2013, 04:29 PM   #3
f0rge
head of infinite swagger
Drives: 2013 FR-S 6MT
are they trying to sell you camber plates or are they going to slot your struts?
2019 Golf R 6MT - current daily...I need another coupe
2008 Civic Si - winter beater
2000 Silverstone M5 6MT - SOLD
2013 Ultramarine FR-S 6MT - Car Journal - SOLD
2004 AlpineWhite M3 6MT - SOLD
f0rge is offline   Reply With Quote
Old 04-18-2013, 07:29 PM   #4
BRZ NA
Drives: WR blue
Wanna know that too,I m looking for some camber at the front without spend thousands of dollar. Does stock car have camber adjustment?
BRZ NA is offline   Reply With Quote
Old 04-18-2013, 08:17 PM   #5
was385
Definitely not camber plates based on the quote I got. Slotting the struts seems like it's probably what they're going to do. Is there anything wrong with doing this?
Old 04-18-2013, 08:27 PM   #6
celica73
Drives: '13 BRZ / '11 Outback / '06 Tundra
Nothing wrong with slotting struts. A lot of them come pre-slotted from the factory.
Not legal for SCCA stock class autocross.
celica73 is offline   Reply With Quote
Old 04-18-2013, 08:36 PM   #7
was385
Off the top of your head do you know if it's legal for ST?
Old 04-19-2013, 07:02 AM   #8
celica73
Not a problem for ST.
Old 04-19-2013, 09:07 AM   #9
was385
Alright thanks. Since you seem to know more about this than me, would this be a bad idea or should it not be an issue?
Old 04-19-2013, 09:39 AM   #10
celica73
Not an issue. KW coilovers come slotted. Neon ACR's were delivered with slotted Koni's from the factory. Slotted struts can slip, just like many other forms of camber adjustment.
Old 04-19-2013, 10:21 AM   #11
grodenglaive
Drives: asphalt FR-S
Damn, I just installed the SPC bolts.
I can see it might be an issue for people that just replace the bolt with one of a smaller diameter to get camber, but quality camber bolts like the SPC should be just as strong as oem, providing they are installed and torqued correctly. There's a few hits on google for broken bolts, but most were oem and I don't see any horror stories or litigation. I'm not too worried about it.
grodenglaive is offline   Reply With Quote
Old 04-19-2013, 10:35 AM   #12
Wepeel
Drives: '13 BRZ Ltd
I ran them in my WRX and STI for thousands of street miles and a lot of autocrosses (30+) and never had any issues with slippage. As long as they are installed correctly (correct hole, tab correctly inserted and torqued to the recommended spec) there shouldn't be any issues.
Wepeel is offline   Reply With Quote
Old 04-19-2013, 11:30 AM   #13
EnjukuAK
Drives: 1996 Nissan 240sx, 1999 Lexus GS300
I run SPC camber bolts on my daily driver (GS300), 40k miles or so on them so far with no issues. It is not beat on really, but it is driven 80+ miles per day highway and city. Never had an instance of them slipping or loosening up.
EnjukuAK is offline   Reply With Quote
Camber Bolts in Rear DIE1000DEATHS Suspension | Chassis | Brakes -- Sponsored by 949 Racing 34 05-13-2015 10:19 AM
H&R Camber Bolts deedz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 09-08-2013 09:00 PM
Where to buy Whiteline Camber Bolts whitefrs Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 07-26-2013 02:05 PM
Question about adjustable LCA's vs Camber Plates vs Camber Bolts djdnz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 03-27-2013 11:38 PM
