Old 10-05-2012, 09:53 PM   #1
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
Where to buy Whiteline Camber Bolts
need to buy a set asap
Old 10-05-2012, 09:55 PM   #2
cnk
Drives: '13 DGM BRZ Limited
Look in the marketplace and PM some vendors.
cnk is offline   Reply With Quote
Old 10-05-2012, 10:11 PM   #3
jamal
jamal's Avatar
Drives: Legacy GT
Or just get some SPC bolts from your local parts store for $40 less.
jamal is offline   Reply With Quote
Old 10-05-2012, 10:41 PM   #4
gmookher
got mine from a site called energysuspension
gmookher is offline   Reply With Quote
Old 10-06-2012, 06:12 AM   #5
Calum
That Guy
Drives: 2013 asphalt FRS MT
go to rockauto and buy camber bolts for whatever subaru you want. Or tougetuning has them for pretty cheap.
Old 10-06-2012, 10:28 AM   #6
No Limit Motorsport
No Limit Motorsport's Avatar
Drives: 2013 DGM BRZ
Send a message via AIM to No Limit Motorsport
I am getting conflicting info. Some books are saying it is a 16mm bolt, others are saying 14mm. The 16mm bolts are on backorder from what I see, the 14mm stuff I have in my warehouse in NY, Eibach brand.
Whiteline part number KCA416 is on a special order basis at two of the big Whiteline distributors
Adam
No Limit Motorsport is offline   Reply With Quote
Old 10-06-2012, 10:42 AM   #7
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Adam
i need at least -1.5 degreess
Old 10-06-2012, 10:53 AM   #8
No Limit Motorsport
I am talking about the diameter of the bolt 14mm or 16mm. All the camber bolts will give that much adjustment.
Old 10-09-2012, 02:54 PM   #9
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
its a 14mm
what brand do you have in stock and how much>
Old 10-09-2012, 03:00 PM   #10
No Limit Motorsport
its a 14mm
Eibach part number 5.81260K. Same as WRX/STi.
$20 at the store.
Just make sure this part number will work, because they don't have it listed as an application.
Old 10-09-2012, 03:21 PM   #11
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
I'm pretty sure it would work, Eibach and SPC share the same parts on some camber kits i know the Eibach camber kit for my TSX was the same as the SPC kit.
JoeBoxer is offline   Reply With Quote
Old 10-09-2012, 11:20 PM   #12
gmookher
its a 14mm
I'm using a 16mm bolt in the upper bolt of my brz, same as your frs
You can use the 14mm ones but there is alot of play. I returned mine and got KCA416; fits much better since the oe bolt has a 16mm shoulder
Old 10-10-2012, 02:20 AM   #13
jamal
jamal's Avatar
Drives: Legacy GT
14mm would go in the lower hole.
No problems getting the tabbed washer completely perpendicular to the strut with the 16mm bolts? I was slightly concerned that the hole on the flange side of the strut would be 16mm but the hole on the nut side would be 14mm, in which case the aftermarket bolt wouldn't work quite right.
Old 10-11-2012, 02:45 PM   #14
Sam Strano
Sam Strano's Avatar
Drives: 2013 FR-S Asphalt
I carry the Whiteline bolts. Whiteline lists the KCA414 as the fitment for the car. I have them in stock. KCA416's are special order, but I can get those too. Personally I don't use them as between the adjustment in my KW's and the C-com offset upper mounts I have, I have no need for the camber bolts (which is why I have them in stock, I bought them "just in case").
Sam Strano is offline   Reply With Quote
Crash bolts alignment change ABQautoxer Tracking / Autocross / HPDE / Drifting 39 03-24-2014 05:45 PM
Adjustable Camber Arms vs. Whiteline Camber Bushings digital_assassin Suspension | Chassis | Brakes -- Sponsored by 949 Racing 70 06-02-2013 06:06 AM
Another crash bolts alignment thread jeebus Suspension | Chassis | Brakes -- Sponsored by 949 Racing 42 10-28-2012 12:29 AM
seat bolts? zooki Cosmetic Modification (Interior/Exterior/Lighting) 3 08-29-2012 06:00 PM
replace front crash bolts to add camber? Matt Andrews Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 06-15-2012 10:05 AM
