Old 03-21-2013, 06:41 PM   #1
deedz
Drives: Rocket Bunny FR-S
H&R Camber Bolts
Just stumbled upon a few people using these on the forum and wondering if anyone can give any input on these as an alternative to rear control arms and front top hats? Im running kw v3s with stock top hats right now and would like some camber, toe and caster adjustability. Thanks!
deedz is offline   Reply With Quote
Old 03-21-2013, 06:48 PM   #2
SubieNate
SubieNate's Avatar
Drives: 2013 FR-S Ultramarine
The won't help you in the rear as it's not a McPherson setup. Go for it in the front. I had them on my Impreza with zero issues for three years.
SubieNate is offline   Reply With Quote
Old 03-21-2013, 06:54 PM   #3
Calum
That Guy
Drives: 2013 asphalt FRS MT
Some have been using them in the lower control arms in the rear.
Old 03-21-2013, 07:06 PM   #4
deedz
yea ive been seing people use these bolts in the control arm curious how they would compare to a replacement LCA
Old 03-24-2013, 04:10 PM   #5
deedz
Bump, lookin for somebody who's running them to chime in
Old 03-24-2013, 05:20 PM   #6
VoiD
Drives: 13 WRB BRZ
I got these installed yesterday.. was able to dial back abuot .5 of rear camber.
part number is TC112 and needs to be modified to work. about 5-6 threads needs to be ground flat.
Heard H&R does not like this since it might compromise the structure of the bolt, but it may be a good alternative until I pick up some good LCAs.
VoiD is offline   Reply With Quote
Old 03-24-2013, 08:15 PM   #7
deedz
You were only able to adjust .5 degrees of camber in the rear?! Yea I also heard you would have to shave a bit down but I was hoping for adjustability around the range of 3 degrees of camber atleast
Old 03-24-2013, 08:20 PM   #8
subaruatheart
Drives: Whiteout FR-S
Sounds like it would cost more than buying LCAs if it does fail. SPC LCAs are only around 280 for a pair.
subaruatheart is offline   Reply With Quote
Old 03-24-2013, 10:25 PM   #9
VoiD
Drives: 13 WRB BRZ
I dont think you can get more than 1 degree of camber with these..
Looking at the alignment spec and I was running -2.4 camber on the rear after KW install and used it to dial it down to -1.8
It's a lot cheaper than LCAs since these are less than $50. There seems to be couple of people running these. I'll have to keep an eye how these hold up over time..
Old 03-24-2013, 11:01 PM   #10
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
I was prolly one of the 1st guys running these. Its easy to do, ask chris at perrin for instructions on what and how much to grind, they do add some adjustability to the tune of 3-4mm in each direction. Much cheaper than LCA, and if all youre looking for is to make symmetrical, its a far cheaper effort than LCA. I run them and highly recommend them. Its not for our car, but can be made to fit and its good quality steel
Huehuecoyotl is offline   Reply With Quote
Old 03-25-2013, 08:25 PM   #11
itdansharpe
itdansharpe's Avatar
Product link? I am in for something like this...
New: 2014 6MT Asphalt Rota Titan 17x9, RS-3 V2, Skunk2 Pro-C, Eibach Sway Bars, Password:JDM Strut Tower Bar, Perrin MCB, StopTech Stainless Lines, Hawk HP+, Nameless 3" Exhaust, VG Sharkfin, FIVE:AD Spoiler, DDM Tuning HID's 5k, HID
Old: 2013 6AT Boosted Firestorm..
itdansharpe is offline   Reply With Quote
Old 03-25-2013, 10:17 PM   #12
Huehuecoyotl
H&R Triple C Camber Adjustment Bolts TC112
http://www.carpartparadise.com/h-r-t...nt-bolts/TC112
Perrin performance is where I got mine
Old 04-22-2013, 02:45 AM   #13
koevasi
koevasi's Avatar
Drives: 1
Would very much appreciate additional info on these H&R camber bolts.
Don't have the necessary time/tools for the bushing and don't want to spend the extra $$ for lower control arms when I have less than a degree of camber to dial out.
koevasi is offline   Reply With Quote
Old 04-22-2013, 09:23 AM   #14
OrbitalEllipses
Drives: Attitude
SPC camber arms aren't that expensive, compared to other arm options.
DIY | Video Installing Camber Crash Bolts Dezoris DIY (Do-It-Yourself) Guides 24 09-06-2016 11:07 AM
Where to buy Whiteline Camber Bolts whitefrs Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 07-26-2013 02:05 PM
Whiteline Camber bolts question (KCA416) ML Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 04-02-2013 11:25 AM
SPC/Whiteline front camber bolts in GTA? f0rge CANADA 2 03-20-2013 10:56 PM
