Old 04-11-2013, 01:12 PM   #1
DIE1000DEATHS
TechNINJA
DIE1000DEATHS's Avatar
Drives: Whiteout MT, 87 Mustang, 09 RUCKUS
Camber Bolts in Rear
I've seen one member make mention of having these bolts in the rear, that they acquired from Perrin. I am interested in this as I don't feel I need the extra hundred dollar Whiteline camber bushings.
Any suspension experts have opinions on using this in the rear? I don't see why it would be any riskier or not useful than using them on the fronts.
DIE1000DEATHS is offline   Reply With Quote
Old 04-11-2013, 01:29 PM   #2
wparsons
wparsons's Avatar
The risk is that they were designed to be used up front and have to be ground down slightly to work in the rear. From what I've seen there's no real risk, but the manufacturers won't support it if you've modified the bolt at all.
flickr
Old 04-11-2013, 01:50 PM   #3
TemeCal
Drives: 86
I've seen a few people running these in the rear:
H&R Camber Bolts
I'm hoping others can chime in, because I'm looking to do it myself. For $50, I wouldn't mind getting a little more camber in the rear.
TemeCal is offline   Reply With Quote
Old 04-11-2013, 02:58 PM   #4
DIE1000DEATHS
TechNINJA
I did read he had to remove a few threads to make them fit, which doesn't worry me. I've looked around and notice bolt kits for several other models (WRX, 350/370z) that would incline me to think the manufacturers are just behind on getting bolts out for the twins...
Old 04-11-2013, 03:21 PM   #5
DIE1000DEATHS
TechNINJA
From the tech at Perrin, the H&R TC112 bolts are the ones you need (but do need modification). I'd imagine the 12mm SPC bolts could work too.
Old 04-11-2013, 03:32 PM   #6
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
So were do these install in the rear? Lca I assume
IG-Joey_Soul
Old 04-11-2013, 03:42 PM   #7
bakerr6
Drives: 2013 raven black fr-s
They can be used once ground down. From my personal preference, I know I will probably make additional suspension changes in the future, and it makes more sense to spend a few extra dollars to have the extra adjustability.
bakerr6 is offline   Reply With Quote
Old 04-11-2013, 03:43 PM   #8
DIE1000DEATHS
TechNINJA
Just like a camber bolt would be utilized in the front, in the upper of the two bolts that secure the bottom of the strut/shock.
Old 04-11-2013, 03:48 PM   #9
f0rge
head of infinite swagger
Drives: 2013 FR-S 6MT
i'm interested in this as well, except to remove rear camber.
2019 Golf R 6MT - current daily...I need another coupe
2008 Civic Si - winter beater
2000 Silverstone M5 6MT - SOLD
2013 Ultramarine FR-S 6MT - Car Journal - SOLD
2004 AlpineWhite M3 6MT - SOLD
f0rge is offline   Reply With Quote
Old 04-11-2013, 03:56 PM   #10
DIE1000DEATHS
TechNINJA
That's what I'll be using it for as well. I figured this was an easier, more cost efficient option for me, as opposed to the Whiteline kit. I am not building a track car, but would like to be able to dial in my suspension properly with coilovers.
Old 04-11-2013, 04:01 PM   #11
f0rge
If you're so inclined you should do a DIY guide, there's so much misinformation about this that a proper guide would clear up.
Old 04-11-2013, 04:06 PM   #12
bakerr6
A DIY is something I would strongly avoid for this, just for the simple fact that a very important part has to be modified correctly. I would not want anyone to get hurt for modifying an aftermarket part to make it "fit"
Old 04-11-2013, 04:15 PM   #13
grodenglaive
Drives: asphalt FR-S
No, the rear suspension is not a MacPherson strut, we are using the bolt on the lower control arm instead. I just ordered a pair of TC112's - I'll post the install when it comes in if no one beats me to it.
grodenglaive is offline   Reply With Quote
Old 04-12-2013, 01:21 AM   #14
VoiD
Drives: 13 WRB BRZ
this is what needs to be done to the bolts.
It installs on the inner most hole of the control arm.
Not sure how much adjustment this allows but I was able to correct .5- .6 or negative camber which was all I needed.
VoiD is offline   Reply With Quote
H&R Camber Bolts deedz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 09-08-2013 09:00 PM
Where to buy Whiteline Camber Bolts whitefrs Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 07-26-2013 02:05 PM
Question about adjustable LCA's vs Camber Plates vs Camber Bolts djdnz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 03-27-2013 11:38 PM
SPC/Whiteline front camber bolts in GTA? f0rge CANADA 2 03-20-2013 10:56 PM
