Drives: '13 black BRZ MT
How much camber wear from Eibach Pro Kit
I am getting pro kits and using camber bolts for the front. If I dont use control arms for the rear, how much camber will I have?
Drives: 2013 FR-S Blue MT
At full negative camber in the front it will probably be around -1 degree.
The rear with lowering springs will be around -2 degrees. |
Drives: FR-S Firestorm 6MT
You sure?
Won't the crash bolt give you at least half a degree? With the bolt and springs I would think we could get up to -1.5 or more. Getbent, is this from experience or research? I'm interested as well since I have the ProKit on the way and will be using the crash bolts also. |
#4 | |
Drives: 13 BRZ
Drives: Your sister
With that modest drop, you'll probably get -1.5 - 2.5 range in the rear without any LCA...but it differs from car to car. My alignment came to be -1.7 on driver side, and -2 on passenger side -- all still within acceptable factory camber range.
Toe is what gives you tire wear; there's little toe-in from the factory to help rear stability. Hope this helped
| The Following User Says Thank You to yohan04 For This Useful Post: | slowbrz (03-21-2013) |
#6 | |
Drives: waiting on a 2021...
I have the Pro-Kit on mine, and my rear alignment specs are the same as Yohan04. I have had them installed for about 10,000 miles now with no kind of abnormal wear visible. I'm running the same size rims and tires all around, so I'm going rotate them every oil change.
2016 4Runner Tail edition
2020 Camry 2020 RAV4 2013 Chevy 3500 4x4 Duramax 1999 Ford F250 Powerstroke, the tow rig 1969 Mustang, the fast car....(: |
| The Following User Says Thank You to zooki For This Useful Post: | slowbrz (03-21-2013) |
#8 | |
May somebody recommend me a good set of camber bolts?
Drives: 2013 Subaru BR-Z Limited
I've got the Sportline springs and my front camber is close to -.7 and rear is -2.0... Nothing to be concerned about. It'll be even less with the Pro kit. I don't think the pro kit is a big enough drop on this car.
#10 |
Yes, just adjustable bolts up front. I thought about buying the Whiteline adjustable bushings for the rear, but haven't seen a need for them.
#11 | |
It should be enough to give you -.5 extra upfront. Cheap (was $5each at my dealer) and pretty easy to get. There is an equivalent Scion part # but I gather it would be more expensive there and it is the same bolt. |
#12 |
Are Whiteline bolts any better? They cost a little more
#13 | |
Drives: ex500r
Dont we already have these crash bolts stock? so how would they improve stock ride? |
#14 |
| Adjustable Camber Arms vs. Whiteline Camber Bushings | digital_assassin | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 70 | 06-02-2013 06:06 AM |
| Camber kit for Eibach prokit | slowbrz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 03-12-2013 07:21 AM |
| Clutch wear? | Pakjk89 | Engine, Exhaust, Transmission | 102 | 04-12-2012 07:21 PM |
| wear your seatbelt... | bofa | Off-Topic Lounge [WARNING: NO POLITICS] | 17 | 07-16-2011 04:25 AM |
