Old 03-09-2013, 10:47 PM   #1
slowbrz
Drives: '13 black BRZ MT
Camber kit for Eibach prokit
Which camber kit should I get?
slowbrz is offline   Reply With Quote
Old 03-09-2013, 11:08 PM   #2
zooki
Drives: waiting on a 2021...
I just went with adjustable camber bolts in the front. The rear were a little (.1 degree) out of spec, but I rotate the tires every oil change(400 miles) and haven't noticed any abnormal wear in the 12,000 miles I've had it lowered on the Eibach Pro's.
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline   Reply With Quote
Old 03-10-2013, 12:18 PM   #3
Captain Insano
Lots of options for this if you search around a bit in this suspension sub-forum. I have adjustable camber bolts up front and SPC lower control arms with camber adjustability in rear running Eibach pro kit springs.
Old 03-10-2013, 12:34 PM   #4
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
This.
Basic, simple, gets the job done, and affordable.
We have SPC camber kits in stock and Whiteline should be coming in very soon. The SPC LCA are also in stock
FT-86 SpeedFactory is offline   Reply With Quote
Old 03-11-2013, 07:46 PM   #5
slowbrz
Can camber bolts be used for the rear as well? I want a cheap option and do not want to spend several hundresd for LCAs
Old 03-11-2013, 08:14 PM   #6
FT-86 SpeedFactory
No, they cannot.
You will need new control arms or you can buy new bushings with adjustable bolts from Whiteline. These will replace the OEM bushings in the control arm to give you camber adjustment. Of course, pushing in bushings is a P.I.T.A, as well....
The Following User Says Thank You to FT-86 SpeedFactory For This Useful Post:
slowbrz (03-18-2013)
Old 03-12-2013, 07:21 AM   #7
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
Originally Posted by FT-86 SpeedFactory View Post
No, they cannot.
The bolts from whiteline work pretty well for the rear. I have my rear camber at -2.0 and am not to the limit of adjustment. The bushings really aren't too bad as long as you have a press (not something that will work with a socket and hammer). But for me the most frustrating part was trying to put the control arm back on the car when the offset bushings aren't aligned the same.
How much camber do you plan on running? I was only able to get -1.3 up front using crash bolts. Will be getting camber plates in the near future.
kask2_6.0 is offline   Reply With Quote
The Following User Says Thank You to kask2_6.0 For This Useful Post:
CRAZY LOW PRICES ON EIBACH SPRINGS (PROKIT AND SPORTLINE) genometuning Brakes, Suspension, Chassis 248 01-17-2015 09:53 PM
Difference in Eibach prokit springs?? leej Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 07-18-2012 08:54 PM
Eibach prokit springs group buy? leej Australia Classifieds 27 06-27-2012 09:47 AM
