Old 03-19-2013, 06:22 PM   #1
slowbrz
Drives: '13 black BRZ MT
How much camber wear from Eibach Pro Kit
I am getting pro kits and using camber bolts for the front. If I dont use control arms for the rear, how much camber will I have?
slowbrz is offline   Reply With Quote
Old 03-19-2013, 11:20 PM   #2
getbent
Drives: 2013 FR-S Blue MT
At full negative camber in the front it will probably be around -1 degree.
The rear with lowering springs will be around -2 degrees.
2013 Scion FR-S | 6MT | UltraMarine
getbent is offline   Reply With Quote
Old 03-20-2013, 09:44 AM   #3
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
You sure?
Won't the crash bolt give you at least half a degree?
With the bolt and springs I would think we could get up to -1.5 or more.
Getbent, is this from experience or research?
I'm interested as well since I have the ProKit on the way and will be using the crash bolts also.
Slick is offline   Reply With Quote
Old 03-20-2013, 09:54 AM   #4
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
Originally Posted by Slick View Post
You sure?
You will get -1.5 tops with the crash bolts. I was only able to get -1.3.
kask2_6.0 is offline   Reply With Quote
Old 03-20-2013, 12:02 PM   #5
yohan04
yohan04's Avatar
Drives: Your sister
With that modest drop, you'll probably get -1.5 - 2.5 range in the rear without any LCA...but it differs from car to car. My alignment came to be -1.7 on driver side, and -2 on passenger side -- all still within acceptable factory camber range.
Toe is what gives you tire wear; there's little toe-in from the factory to help rear stability.
Hope this helped
yohan04 is offline   Reply With Quote
The Following User Says Thank You to yohan04 For This Useful Post:
slowbrz (03-21-2013)
Old 03-20-2013, 11:20 PM   #6
getbent
You sure?
I have Swift springs and the factory crash bolts. Front ended up at -1.2. If you want more you are going to need to do Com-C or some other camber plates.
Old 03-21-2013, 04:21 AM   #7
zooki
Drives: waiting on a 2021...
I have the Pro-Kit on mine, and my rear alignment specs are the same as Yohan04. I have had them installed for about 10,000 miles now with no kind of abnormal wear visible. I'm running the same size rims and tires all around, so I'm going rotate them every oil change.
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline   Reply With Quote
The Following User Says Thank You to zooki For This Useful Post:
Old 03-21-2013, 11:27 PM   #8
slowbrz
May somebody recommend me a good set of camber bolts?
So Im assuming the only thing youre using are camber bolts for the front?
Old 03-21-2013, 11:36 PM   #9
chadstyle
chadstyle's Avatar
Drives: 2013 Subaru BR-Z Limited
I've got the Sportline springs and my front camber is close to -.7 and rear is -2.0... Nothing to be concerned about. It'll be even less with the Pro kit. I don't think the pro kit is a big enough drop on this car.
chadstyle is offline   Reply With Quote
Old 03-21-2013, 11:41 PM   #10
zooki
Yes, just adjustable bolts up front. I thought about buying the Whiteline adjustable bushings for the rear, but haven't seen a need for them.
Old 03-22-2013, 09:26 AM   #11
Slick
Slick's Avatar
I would just go with the Subaru crash bolts (part# 901000394).
It should be enough to give you -.5 extra upfront.
Cheap (was $5each at my dealer) and pretty easy to get.
There is an equivalent Scion part # but I gather it would be more expensive there and it is the same bolt.
The Following 2 Users Say Thank You to Slick For This Useful Post:
Indred (04-16-2013), slowbrz (03-22-2013)
Old 03-22-2013, 11:44 AM   #12
slowbrz
Are Whiteline bolts any better? They cost a little more
Old 03-22-2013, 12:55 PM   #13
Xdragonxb0i
Drives: ex500r
Dont we already have these crash bolts stock? so how would they improve stock ride?
Xdragonxb0i is offline   Reply With Quote
Old 03-23-2013, 08:01 PM   #14
slowbrz
Someone please answer this. I want to buy my camber bolts asap.
Adjustable Camber Arms vs. Whiteline Camber Bushings digital_assassin Suspension | Chassis | Brakes -- Sponsored by 949 Racing 70 06-02-2013 07:06 AM
Camber kit for Eibach prokit slowbrz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 03-12-2013 08:21 AM
Clutch wear? Pakjk89 Engine, Exhaust, Transmission 102 04-12-2012 08:21 PM
wear your seatbelt... bofa Off-Topic Lounge [WARNING: NO POLITICS] 17 07-16-2011 05:25 AM
