Drives: 2013 WRB BRZ
Eibach springs
Hey, so if i lower my car with the Eibach Pro kit springs (1inch) do i have to realign/adjust anything?
The Answer
Drives: Mazda 2
It's a mild drop, I'd get it aligned at least it might change the toe value off.
Ridge Racerrrrrrrrr
Chamber bolts will give you adjustability if you NEED it for after market rims.
Drives: Subaru BRZ
Same question here. Still a newbie at this. If i followed it correctly, in dropping the car with Eibach Pro kit springs (1 inch), i should also buy and install camber bolts and bushings, then send my car to a shop and have it aligned. Would that be all as far as the suspension is concerned?
Is the said lowering spring compatible with the stock strut? Or should i expect it to wear down fast? |
#8 | |
Drives: 2014 Widebody Cosworth FR-S
With any aftermarket spring a bit more wear and stress on the strut is to be expected, but being that these springs have a mild bump in spring rate and drop, I would not expect any more noticeable wear on the struts. Hope this helps! ![]() Thanks, Rick |
| The Following User Says Thank You to RallySport Direct For This Useful Post: | pauland (03-22-2013) |
#9 | |
Drives: CBS BRZ
#10 | |
Drives: Subaru BRZ
Got it thanks!
![]() Quote:
#11 |
Drives: Blue FRS 6sp, 95 M3
I had the Sportline Springs installed.
The shop was able to align the front without using aftermarket parts. However, the rear camber has no factory adjustment and will be out of spec with a drop. FWIW, most who go for the dropped look like some additional camber because it looks "JDM, yo!" |
#12 | |
Feel free to contact me directly with any questions, always happy to help. ![]() Thanks, Rick |
#13 | |
Drives: 86
#14 |
Drives: '13 black BRZ MT
will the front and rear have the same amount of camber from prokits?
| Eibach Pro Kit Springs w/ Pics | chonody | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 69 | 03-06-2018 09:26 PM |
| FS: Eibach Sportline Springs | crizkay | Brakes, Suspension, Chassis | 1 | 03-01-2013 10:52 PM |
| FS: EIBACH PRO KIT SPRINGS | BOYCE | Brakes, Suspension, Chassis | 12 | 02-26-2013 10:26 PM |
| alignment with Eibach springs? | zooki | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 20 | 09-17-2012 11:34 AM |
| New Eibach Springs for the BRZ/FT86/FR-S | RallySport Direct | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 07-19-2012 11:05 AM |
