Old 03-18-2013, 07:57 PM   #1
WRB_BRZ
Drives: 2013 WRB BRZ
Eibach springs
Hey, so if i lower my car with the Eibach Pro kit springs (1inch) do i have to realign/adjust anything?
WRB_BRZ is offline   Reply With Quote
Old 03-18-2013, 08:01 PM   #2
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
It's a mild drop, I'd get it aligned at least it might change the toe value off.
Rayme is offline   Reply With Quote
Old 03-18-2013, 08:04 PM   #3
WRB_BRZ
so can i go to like any shop and ask them to realign my car? and on average do you know much that would cost?
Old 03-18-2013, 08:07 PM   #4
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Depending on the shop alignments can run $75-110 all depends on the place. Good idea to get camber bolts and camber bushings as well just in case.
FT-86 SpeedFactory is offline   Reply With Quote
Old 03-18-2013, 08:10 PM   #5
WRB_BRZ
um i'm new at this so why would i NEED the camber bolts and bushings?
Old 03-18-2013, 09:02 PM   #6
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Chamber bolts will give you adjustability if you NEED it for after market rims.
Old 03-20-2013, 04:52 PM   #7
pauland
pauland's Avatar
Drives: Subaru BRZ
Same question here. Still a newbie at this. If i followed it correctly, in dropping the car with Eibach Pro kit springs (1 inch), i should also buy and install camber bolts and bushings, then send my car to a shop and have it aligned. Would that be all as far as the suspension is concerned?
Is the said lowering spring compatible with the stock strut? Or should i expect it to wear down fast?
pauland is offline   Reply With Quote
Old 03-20-2013, 05:05 PM   #8
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
The bushings and bolts are always a good idea, but perhaps not a requirement to get the alignment "within spec", but if you were wanting the camber bolts and bushings, it would be the best time to install them for sure.
With any aftermarket spring a bit more wear and stress on the strut is to be expected, but being that these springs have a mild bump in spring rate and drop, I would not expect any more noticeable wear on the struts.
Hope this helps!
Thanks,
Rick
RallySport Direct is offline   Reply With Quote
The Following User Says Thank You to RallySport Direct For This Useful Post:
pauland (03-22-2013)
Old 03-20-2013, 10:19 PM   #9
Pandle
Drives: CBS BRZ
Hope this helps!
Thanks,
Rick
Do you need to buy a new set of bushings when getting front camber bolts or can you get away with just the bolts themselves? And are rear control arms worth spending money on for such a short drop or would they be fine left alone? I have the same springs. (not trying to thread jack)
Pandle is offline   Reply With Quote
Old 03-21-2013, 06:45 AM   #10
pauland
pauland's Avatar
Drives: Subaru BRZ
Got it thanks!
Hope this helps!
Thanks,
Rick
Old 03-21-2013, 08:16 AM   #11
maj75
Drives: Blue FRS 6sp, 95 M3
I had the Sportline Springs installed.
The shop was able to align the front without using aftermarket parts. However, the rear camber has no factory adjustment and will be out of spec with a drop. FWIW, most who go for the dropped look like some additional camber because it looks "JDM, yo!"
maj75 is offline   Reply With Quote
Old 03-21-2013, 12:24 PM   #12
RallySport Direct
If you are okay with the camber on the car, then there is no need for any bolts or bushings, however if you are trying to change the camber, then going with the bolt, rear bushings or even the rear control arms may be the way to go. I don't have the numbers in front of me, but when we got an alignment after the Eibach springs, the numbers were not too far from factory, but it really comes down to personal preference and how you want the car to feel or look.
Feel free to contact me directly with any questions, always happy to help.
Thanks,
Rick
Old 03-21-2013, 01:40 PM   #13
HATED1
HATED1's Avatar
Drives: 86
How many degrees of rear camber?
HATED1 is offline   Reply With Quote
Old 03-21-2013, 10:14 PM   #14
slowbrz
Drives: '13 black BRZ MT
will the front and rear have the same amount of camber from prokits?
slowbrz is offline   Reply With Quote
Eibach Pro Kit Springs w/ Pics chonody Suspension | Chassis | Brakes -- Sponsored by 949 Racing 69 03-06-2018 09:26 PM
FS: Eibach Sportline Springs crizkay Brakes, Suspension, Chassis 1 03-01-2013 10:52 PM
FS: EIBACH PRO KIT SPRINGS BOYCE Brakes, Suspension, Chassis 12 02-26-2013 10:26 PM
alignment with Eibach springs? zooki Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 09-17-2012 11:34 AM
New Eibach Springs for the BRZ/FT86/FR-S RallySport Direct Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 07-19-2012 11:05 AM
