Old 02-11-2013, 02:13 AM   #1
rhood168
rhood168's Avatar
Drives: Black Subaru Brz Limited
Strange Tapping noise from under car after use
So whenever i get out the car after its on for awhile or I get to a destination I hear a strange tapping noise under the car. Sound like its coming from the front of the car right under everything. The noise is like water drops tapping against a metal sheet at the bottom and its been haping since around 2k . Now at 3k I'm getting worried because apparently its not normal. Even when the ac is off the whole ride the sound still happens. Does this sound happen to anyone else. Don't have a lift to check and it doesn't seem to leave a puddle anywhere so maybe its on top of some plate near the engine. Does anyone else have/hear this problem?
rhood168 is offline   Reply With Quote
Old 02-11-2013, 03:40 AM   #2
roddy
roddy's Avatar
Drives: '13 Ultramarine
Sounds like a common complaint...perfectly normal. The exhaust on this car uses a lot of heat shielding around the exhaust manifold, and that sound is the heat shields contracting as they cool. It is normal for any car, but especially noticeable on this one. I have become used to it.
Old 02-11-2013, 04:06 AM   #3
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Probably expanded exhaust metal contracting as it cools down.
Old 02-11-2013, 05:19 AM   #4
Minovsky
Minovsky's Avatar
Drives: Fr-s 2013 white out
Normal like tht on mine too
Minovsky is offline   Reply With Quote
Old 02-11-2013, 08:09 AM   #5
whtchocla7e
Drives: 2013 FR-S Hot Lava
The expended metal heat shields contract as they cool down.
Live to drive another day
whtchocla7e is offline   Reply With Quote
Old 02-11-2013, 08:23 AM   #6
CaptainSlow
CaptainSlow's Avatar
No, this has to be a quality control issue with Toyota. How can they release a car with this many problems? Take it to the dealer and make them replace the whole exhaust
/sarcasm
Ultramarine 2013 Scion FR-S 6MT
CaptainSlow is offline   Reply With Quote
Old 02-11-2013, 09:16 AM   #7
OrbitalEllipses
Drives: Attitude
Normal. My WRX did the same thing; as other's have said, it's metal contracting after it's been heated up. All cars do this, some are noisier.
/sarcasm
Old 02-11-2013, 09:34 AM   #8
hunter3232792
hunter3232792's Avatar
Drives: FRS
/sarcasm
this ^^
hunter3232792 is offline   Reply With Quote
Old 02-11-2013, 03:29 PM   #9
rhood168
rhood168's Avatar
Great to know I thought I had some type of coolant leak because of the levels being so low. Thought I was nuts. Thank you guys still kind of strange that's the noise it makes.
Old 02-11-2013, 08:14 PM   #10
BRZnut
Drives: BRZ DGM Limited
Mine does it too , esp after spirited driving. Sounds like metal as it cools down.
Old 02-12-2013, 02:16 AM   #11
random0
Drives: '13 FR-S, MT Asphalt
Normal on mine too. Definitely sounds like hot metal contracting in cooler temperatures. I compare it to that feeling you get after you finish a hard workout and you take a moment to take a deep breath and stretch...
...before hopping back in the driver's seat and going another few sprints down your favorite twisty roads.
random0 is offline   Reply With Quote
Strange Noise from rear of car while OFF mike2100 Issues | Warranty | Recalls / TSB 23 12-17-2014 08:14 PM
Strange noise at 2k RPMs Cajun Issues | Warranty | Recalls / TSB 3 11-29-2012 10:30 PM
Strange Sound From Noise Tube bkneal Issues | Warranty | Recalls / TSB 6 11-01-2012 04:17 PM
BRZ/FRS automatic owners ... Strange noise Delacruzmd Issues | Warranty | Recalls / TSB 6 10-16-2012 07:16 AM
Strange noise Random_Art Other Vehicles & General Automotive Discussions 15 06-03-2011 03:31 PM
