Old 05-31-2011, 07:44 PM   #1
Random_Art
professional smartass
Random_Art's Avatar
Drives: 16 speed mountain bike...
Strange noise
Hey guys. I'm hoping y'all might be able to help me diagnose a weird sound. I have a 2004 mountaineer that's RWD that's making this odd rhythmic "thrum thrum thrum" kind of sound from the passenger front wheel well. The sound tempo increases with speed as opposed to engine RPM and is worse on right hand turns. On left hand turns, the sound seems to be absent. I did a brake job about a month ago, replacing the rotors and pads. I looked into the wheel well with the wheel turned all the way to the right to see if the tire may be rubbing against something, but it doesn't seem to be. Any ideas?
Goodbye Celica, you served me well.
http://artsofrandomness.blogspot.com/
Random_Art is offline   Reply With Quote
Old 05-31-2011, 08:10 PM   #2
Midship Runabout
formerly Dixie Normous
Midship Runabout's Avatar
Drives: The ladies wild!
Wheel hub.
Jack up that wheel. Put your hands at 12 & 6 and shake. If you have any play, its bad
Midship Runabout is offline   Reply With Quote
Old 05-31-2011, 08:38 PM   #3
Exage
GL 86!
Exage's Avatar
Drives: Maybe FR-S... maybe not
Does the steering wheel shake or vibrate when the noise is occurring?
Exage is offline   Reply With Quote
Old 05-31-2011, 08:43 PM   #4
RRnold
2 wheel member
RRnold's Avatar
Drives: JZA80, 997.1, Taco
Originally Posted by Midship Runabout View Post
Wheel hub.
^ I was going to mention the same thing; sounds like the passenger bearing. It's a problem on the Tacomas, esp the front passenger side.
Old 06-01-2011, 12:01 AM   #5
Want.FR-S
Want.FR-S's Avatar
Drives: 4 Wheels Auto
Wheel hub.
I was thinking the same. I actually have at least two occurrences on different cars with passenger side wheel hub, and the symptom is almost the same.
I did not know the way to diagnose, though. Thanks for the tip.
Want.FR-S is offline   Reply With Quote
Old 06-01-2011, 10:36 AM   #6
Random_Art
Random_Art's Avatar
Wheel hub.
Thanks for the tip, I'll try that later today
no, but the noise can be felt through the floor.
Old 06-01-2011, 03:35 PM   #7
Random_Art
Random_Art's Avatar
Just jacked up the truck and wiggled both front wheels. it's definitely a bad wheel hub on the driver's side. Thanks for the info!
Old 06-01-2011, 04:39 PM   #8
Random_Art
Random_Art's Avatar
And now I managed to limp it back home from the auto parts store. On the way home, the hub seems to have totally nuked itself and possibly took a brake line with it. A half mile from home the truck started lurching from side to side and it took mashing the brake pedal all the way to the floor to get it to slow. Fortunately I was only doing 15-20mph. and when I got out, there was blue smoke coming from the hub.
Old 06-01-2011, 04:54 PM   #9
Want.FR-S
Want.FR-S's Avatar
Wow. That is serious. Are you going to post some worn out hub picture?
Old 06-01-2011, 05:41 PM   #10
Giccin
Giccin's Avatar
Yea pics! Would be awesome.
I am the Ice Queen.
Logic > Emotion
┬──┬◡ノ(° -°ノ)
TOYOTA FT-86
Old 06-01-2011, 08:30 PM   #11
Random_Art
Random_Art's Avatar
haha, I didn't even think about that. I got the new hub installed and the truck is running fine now. Apparently the brake issue was due to boiling the brake fluid when the hub started cocking back to the point where the pads were in constant contact with the rotor. The blue smoke was from the grease that was on the over heated rotor. Looks like I'll have to flush the brake fluid and get the rotor turned if the brakes don't firm back up any more.
I'll go out in a bit and get a picture of the old hub since it's sitting on top of my scrap parts pile waiting for a run to the scrap yard.
Old 06-02-2011, 12:48 PM   #12
Random_Art
Random_Art's Avatar
Here's the nuked wheel hub. The globs of grease clinging to it are full of metal shavings.
Old 06-03-2011, 12:21 PM   #13
Want.FR-S
Want.FR-S's Avatar
Thanks for the picture.
Does it take long for you to remove the wheel hub? It seems that after you got the rotor off, there are three nuts that you need to remove for the wheel hub. Is this correct?
Thanks.
Old 06-03-2011, 12:54 PM   #14
Random_Art
Random_Art's Avatar
Yeah, I was surprised that it was actually easier than doing a brake job since you don't have to fiddle with depressing caliper pistons and worming the new pads into place, bleeding the brakes, etc. once you have the caliper and rotor off, it's just three bolts that slide through the back of the spindle and thread directly into the wheel hub and disconnecting the ABS wire from under the hood. The most time I spent was cracking those three bolts loose. I'm just glad it's not a 4WD model, otherwise I would have to have gone through the pain of dealing with the drive axle, too.
