Old 01-13-2013, 02:31 PM   #1
crazyfrenchbiker
Hot Lava 6MT
crazyfrenchbiker's Avatar
Drives: Hot Lava FR-S
How did you wire your new speakers?
To those of you that installed a new set of speakers/amp, how did you wire them?
  • Existing wiring cutting the harness from the stock amp?
  • Existing wiring using a harness on the stock amp
  • All new wiring
crazyfrenchbiker is offline   Reply With Quote
Old 01-14-2013, 12:12 AM   #2
whataboutbob
AutoX-10/10ths every run
RCAs from the deck to the sub amp. Vampire taps for the separates in the doors in conjunction with some aftermarket adapters.
Build thread:Here
Old 01-14-2013, 11:37 AM   #3
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
  • All new wiring
Haven't done mine yet but I'm running RCAs/rem wire back to the amps, then all new wiring to the speakers from the amps. Going to just disconnect the stock wiring and leave in place in case I ever go to remove my system or change to something else.
pheoxs is offline   Reply With Quote
Old 01-16-2013, 03:14 PM   #4
crazyfrenchbiker
Hot Lava 6MT
Did you use vampire/t taps at each end of the stock wires? IE on the ends in the truck and in the doors?
Old 01-16-2013, 03:15 PM   #5
crazyfrenchbiker
Hot Lava 6MT
That was what I originally wanted to do, however I couldn't figure out how to get my wire in passed the door molex.
Old 01-16-2013, 03:48 PM   #6
whataboutbob
I ordered these off Amazon to give me a way to tap into the door speaker wires cleanly:
[ame="http://www.amazon.com/gp/product/B0002BBP7Y"]Amazon.com: Metra 72-8104 Speaker Connector for Select Toyota Vehicles: Electronics[/ame]
I then just vampire tapped into the end of the wires coming off this harness.
As for the deck connections, I'm running all of the stock/aftermarket speakers off the deck using an adaptor and the factory harness . I'm only running my subs off an AMP that I've mounted in the trunk.
Build thread:Here
The Following User Says Thank You to whataboutbob For This Useful Post:
lordtakuban (01-17-2013)
Old 01-16-2013, 04:45 PM   #7
cruzinbill
Drives: Argento 6spd FR-S
3 Fresh runs/side of 14g to the fronts, rear speakers removed.
cruzinbill is offline   Reply With Quote
Old 01-16-2013, 05:08 PM   #8
crazyfrenchbiker
Hot Lava 6MT
How did you get the runs in the door molex?
Old 01-16-2013, 06:29 PM   #9
cruzinbill
Only one run goes into the door, just take your time and use a wire puller to pull it through the grommet. Took about 20 mins per door.
Old 01-16-2013, 08:56 PM   #10
crazyfrenchbiker
Hot Lava 6MT
Would you happen to have a link to a wire puller?
Old 01-16-2013, 09:49 PM   #11
GremlinGSP
I ran all new.
To get it through the door I just un hooked the rubber boot and fished it through. sometimes a metal close hanger can be used if needed but I didn't have to go that far.
GremlinGSP is offline   Reply With Quote
Old 01-16-2013, 09:59 PM   #12
crazyfrenchbiker
Hot Lava 6MT
Originally Posted by GremlinGSP View Post
I ran all new.
Unhook the boot and start fishing? Fish in the boot right? I'll give it a shot this weekend.
Old 01-16-2013, 11:30 PM   #13
rmjjensen
rmjjensen's Avatar
Drives: 2013 Subaru BRZ Limited in WRB
Go in your closet and grab an old metal hanger. Untwist the hook end and you'll have a great wire puller. Just be careful as the edges can be sharp and puncture existing wires ...don't go shoving it in.
Fish the hanger through, tape your wires to the end, lube it up with some spit and pull it through.
rmjjensen is offline   Reply With Quote
Old 01-16-2013, 11:36 PM   #14
crazyfrenchbiker
Hot Lava 6MT
Originally Posted by rmjjensen View Post
[...] ...don't go shoving it in.
[...] tape your wires to the end, lube it up with some spit and pull it through.
Are we still talking about car audio here?
Wire Tuck DIM Cosmetic Modification (Interior/Exterior/Lighting) 20 08-11-2013 04:54 PM
best way to install 12v wire for amp?? derka-derka DIY (Do-It-Yourself) Guides 5 03-17-2013 12:57 PM
Dash Top Speakers / Rear seat speakers Laurie Electronics | Audio | NAV | Infotainment 9 03-01-2013 06:31 PM
wire routing for door speakers derka-derka Electronics | Audio | NAV | Infotainment 6 12-13-2012 09:49 PM
Reverse Wire Tap wire Location? Norkoastal Electronics | Audio | NAV | Infotainment 2 10-19-2012 10:22 AM
