Old 12-01-2012, 02:48 AM   #1
derka-derka
Drives: Silver GT86
best way to install 12v wire for amp??
planning to install an aftermarket 2din unit with amp.
My local AV store wants to charge me $300 for installation. so i said no.
wheres the best place to run the 12v wire to the amp, to be installed under the passenger seat?
And also, i had experience installing head units before, but quite unsure where to drill holes under the passenger seat. i dnt wanna find a oil leak after getting my HU working.
any advice is great!!
thnx
derka-derka is offline   Reply With Quote
Old 12-01-2012, 04:32 AM   #2
chris's fr-s
@theexquisite86
chris's fr-s's Avatar
Drives: 2013 Firestorm FR-S
thnx
http://frsdiy.blogspot.com/2012/11/d...oofer.html?m=1
As for mounting under the seat, I'm not sure but there is a factory amp on the drivers side of the trunk, you could probably remove it and add yours or mount close to it, if you still want to mount under the passenger seat run the power wire under the carpet like I mention in my diy
chris's fr-s is offline   Reply With Quote
Old 12-01-2012, 07:56 AM   #3
JWMotoring
JWMotoring's Avatar
Drives: FR-S baby!
I like this step lol
The first thing you need to do is Disconnect the battery. Im not including a picture because if you dont know how you need to stop what your doing before you break something.
JWMotoring is offline   Reply With Quote
Old 12-01-2012, 08:55 AM   #4
derka-derka
Drives: Silver GT86
cheers. ill have a look at ur diy..i always disconnect battery when i do anything electrical. had bad experiences before and learnt my lesson
Old 12-01-2012, 10:18 AM   #5
rmjjensen
rmjjensen's Avatar
Drives: 2013 Subaru BRZ Limited in WRB
1) Remove the battery
2) Presto - you see a BIG ASS rubber grommet with plenty of room to add a new power wire
3) Run the new wire all the way down the passenger side of the car
if you remove the battery the install is ridiculously easy
rmjjensen is offline   Reply With Quote
Old 03-17-2013, 12:57 PM   #6
Hardrock4445
Hardrock4445's Avatar
I ran my power wire through my sound tube grommet.
Mods: Perrin CAI, JDL EL header, DC sports Catless front pipe, top speed auto pro-1 cat-back, H&R sport line springs, Headlight blackout, "Demon eyes"
Hardrock4445 is offline   Reply With Quote
Found Loose wire...?? IDK what it is rikdrt1 Scion FR-S / Toyota 86 GT86 General Forum 34 06-10-2020 12:42 PM
Wire Tuck DIM Cosmetic Modification (Interior/Exterior/Lighting) 20 08-11-2013 04:54 PM
Wire LED DRLs to fog lights or headlights Cameronghanson DIY (Do-It-Yourself) Guides 0 10-29-2012 07:52 PM
Reverse Wire Tap wire Location? Norkoastal Electronics | Audio | NAV | Infotainment 2 10-19-2012 10:22 AM
drive-by-wire systems... Axel Other Vehicles & General Automotive Discussions 6 01-15-2010 01:41 PM
