Old 11-12-2012, 12:54 PM   #1
Unleashed
Unleashed's Avatar
Drives: 13' WRX
Clear Matte PlastiDip
I am totally doing this to my car! My color all frosted is going to look sick!
Unleashed is offline   Reply With Quote
Old 11-13-2012, 01:15 AM   #2
mashal
DADA
mashal's Avatar
Drives: 2013
Sick
I-Tapatalk
mashal is offline   Reply With Quote
Old 11-13-2012, 02:08 AM   #3
chimmay
chimmay's Avatar
Drives: Scion FR-S, Scion TC
im totally down to do this. lol and if it doesnt look good, peel that right off. maybe buy a small bottle and spray a small section to see what itll look like.
chimmay is offline   Reply With Quote
Old 11-13-2012, 05:21 AM   #4
trinitron
Drives: gts 86
I think it'll look good for black, wrb and lava. Other colors not so much....
trinitron is offline   Reply With Quote
Old 11-13-2012, 08:13 AM   #5
whaap
whaap's Avatar
It's a good look but I do see a potential problem. Anything and everything that brushes against the finish whether parked or driving down the highway will leave a buff (scuff) mark that can't be removed. That is unless you strip that particular panel and spray it again.
whaap is offline   Reply With Quote
Old 11-13-2012, 08:46 AM   #6
Got3n
86-75309
Got3n's Avatar
Drives: Toyota FR-S
i wonder if you strip it off does it hurt the original paint.
Got3n is offline   Reply With Quote
Old 11-13-2012, 09:31 AM   #7
White Shadow
Drives: 12,000 miles per year
No, it peels right off and the paint underneath is exactly as it was before.
White Shadow is offline   Reply With Quote
Old 11-13-2012, 09:43 AM   #8
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Be careful with this. It does not peel off as easy as you think. We would know.
http://i.imgur.com/KLrnYh.jpg
post_break is offline   Reply With Quote
Old 11-13-2012, 10:02 AM   #9
Oilers99
Oilers99's Avatar
Drives: Argento MT
Agreed. Great product but after taking it off claybarring was necessary on the section I did as there was adhesive residue. Judging by the removal time of the two strips I did, which was about 1.5 hrs, I'd say the entire car would be about 4-6 hours for removal and claybarring done right, then one would be well served to apply a wax or sealant on the claybarred area as well given the abrasiveness of even the mildest of clays.
Oilers99 is offline   Reply With Quote
Old 11-13-2012, 10:03 AM   #10
dabocx
dabocx's Avatar
Drives: Scion FRS
Id love to try this on my blue FRS but the whole peeling off thing is sketchy. That and will it really look good 3 months down the line?
dabocx is offline   Reply With Quote
Old 11-13-2012, 11:04 AM   #11
White Shadow
If you had problems peeling it off, it's probably because it wasn't applied thick enough (or not enough coats were applied). Personally, I applied four coats and it was very easy to peel off without leaving any sign of residue behind.
I sprayed a trim piece with one coat and then decided that I wanted to leave the trim the original color instead. Peeling it off was a major pain in the ass because the Plasti-Dip was too thin. Taking the advice of others, I put a few more coats on, let it dry for a full day, and then it all peeled right off no problems at all.
Old 11-13-2012, 12:11 PM   #12
TIE Pilot
TIE Pilot's Avatar
Drives: TIE interceptor; BRZ13
Looks more mate than frozen.
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." Jeremy Clarkson
TIE Pilot is offline   Reply With Quote
Old 11-14-2012, 06:16 PM   #13
Oilers99
Oilers99's Avatar
Drives: Argento MT
Nah mine came off fine as well but did leave a slightly "tacky feel" on the area it was removed from. Maybe even a car wash could have taken off this tackiness but I'm anal so did a claybar..
Another DIY PlastiDip Wheels JDMenrique DIY (Do-It-Yourself) Guides 61 03-01-2019 07:44 PM
Plastidip section Oilers99 Cosmetic Modification (Interior/Exterior/Lighting) 29 02-13-2015 03:16 AM
Plastidip Smoke Sutty Cosmetic Modification (Interior/Exterior/Lighting) 1 09-29-2012 05:04 PM
Plastidip Clear Flat? CharlieChaos Cosmetic Modification (Interior/Exterior/Lighting) 8 08-15-2012 10:44 AM
A little plastidip test raphymartinez FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 7 06-11-2012 08:45 AM
