Old 10-21-2012, 11:27 PM   #1
JDMenrique
DEEEERP
JDMenrique's Avatar
Another DIY PlastiDip Wheels
Myself and my buddy Sam(PRORICAN) got a little bored today and decided to PlastiDip our wheels to offer a little protection for the upcoming winter and well cuz it looks good too. I'm sure there are several of these out there but another one doesn't hurt.
1. Remove: First off, jack your car up safely and remove the wheels.
2. Clean: We used a mild detergent with water to basically wash the wheels.
3. Dry: Thoroughly dry your wheels
4. Clean... AGAIN: We decided to use Isopropyl Alchohol instead of Denatured Alcohol for further cleaning purposes. I feel that Denatured leaves a small hazy sheen behind and we didn't want that.
5. PREP YOUR WHEEL: This should be a fairly easy but lengthy process. The better you prep the better your work will be. We used painters tape and old newspaper. Index cards would work as well.
6. Apply PlastiDip: This isn't difficult if done correctly. Apply in a wind/dust free environment. You want to avoid over-spraying that will cause drips. Nice and medium paced passes over the wheel. Once on each side of the wheel then down each spoke on both sides. Keep the coats light! I did a total of 4 coats, about 15-20 mins between coats and it came out great.
As seen on here:
[ame="http://www.youtube.com/watch?v=NMITPU-tM60"]www.youtube.com/watch?v=NMITPU-tM60[/ame]
7. Dry: Don't rush your work now. Let the wheels sit for about an hour to let it dry. The can says 4 hours till dry but one should be enough to at least put on the car. Peel off all prep work, slowly!
8. Install: Carefully install your wheels. They should be dry to the touch and not tacky at this point. Careful with the lug nuts.
Enjoy. It got dark on us so I'll post more pics tmw. I'll answer any questions if you have any.
More pics:
JDMenrique is offline   Reply With Quote
Old 10-21-2012, 11:36 PM   #2
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
fuckin ricans....
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 10-22-2012, 12:06 AM   #3
wheelhaus
wheelhaus's Avatar
lol I have those exact same speakers...
I like the way the stockers look all black, I may jump on the Plastidip wagon.How durable is the bond?
wheelhaus is offline   Reply With Quote
Old 10-22-2012, 01:56 AM   #4
JonnyRocket
"New hotness"
JonnyRocket's Avatar
Drives: WRB Limited MT BRZ
It's all in the prep. A well done plasti-dip (good prep, 4-5 light coats, careful removal of tape, etc) can last months. And if you decide you want to switch things up, it peels right off!
JonnyRocket is offline   Reply With Quote
Old 10-22-2012, 02:14 AM   #5
spitz
spitz's Avatar
Drives: '13 SWP BRZ-L
Looking forward to more pics! Great job!
spitz is offline   Reply With Quote
Old 10-22-2012, 03:11 AM   #6
proficience
proficience's Avatar
Drives: Velocity Orange 86 GTS M/T
You guys might wanna do it in an open well ventilated area lol that stuff is mildly carcinogenic
proficience is offline   Reply With Quote
Old 10-22-2012, 03:17 AM   #7
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
we did this minus all the masking on the wheels and got the same results
the paint just peels offthe tires so i suggest skipping this step
86_ZN6 is offline   Reply With Quote
Old 10-23-2012, 01:03 AM   #8
leeRichard
leeRichard's Avatar
Drives: Argento FR-S 6MT
Looks nice, curious how many cans of PlastiDip did it take?
leeRichard is offline   Reply With Quote
Old 10-23-2012, 05:55 AM   #9
JDMenrique
DEEEERP
JDMenrique's Avatar
it took about 2.5 cans
Old 10-23-2012, 06:04 AM   #10
JDMenrique
DEEEERP
JDMenrique's Avatar
more pics
Old 10-25-2012, 06:03 PM   #11
GTM_Challenge
GTM_Challenge's Avatar
Drives: On track
Plastidip is amazingly durable. I didnt know what to expect when I opened this thread, but the wheels look pretty damn good that way!
GTM_Challenge is offline   Reply With Quote
Old 10-25-2012, 06:12 PM   #12
Yruyur
Yruyur's Avatar
Looks great! I did my center caps only since I have Toyota badges and didn't want to spring for Toyota caps... but may do the wheels now.
Old 10-25-2012, 06:32 PM   #13
.Alex
Drives: Scion
The wheels actually looks alot nicer imo with plastidip. Good job
.Alex is offline   Reply With Quote
Old 10-25-2012, 06:40 PM   #14
zoomzoomers
zoomzoomers's Avatar
Drives: 2013 Subaru SWP BRZ Limited 6AT
Looks good!
Man Law#17:A man in the company of a hot, seductively dressed, woman MUST remain sober enough to fight!
MODS: AVO tubes + filter, Cusco (F) strut brace w/ MC brace, Perrin CBE, Subaru OEM trunk tray, Grimmspeed front license re-locator & hood struts and Beatsonic rear cam.
zoomzoomers is offline   Reply With Quote
Plastidip Smoke Sutty Cosmetic Modification (Interior/Exterior/Lighting) 1 09-29-2012 05:04 PM
plastidip practice on the FR-S nytfury Cosmetic Modification (Interior/Exterior/Lighting) 18 08-27-2012 02:35 PM
Plastidip emblem??? jarviz Cosmetic Modification (Interior/Exterior/Lighting) 20 08-02-2012 03:21 PM
Plastidip and Vinyl Help CharlieChaos Cosmetic Modification (Interior/Exterior/Lighting) 8 07-25-2012 01:56 PM
A little plastidip test raphymartinez FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 7 06-11-2012 08:45 AM
