Old 03-20-2026, 08:17 PM   #1
hotrod1442
Drives: 2013 FRS's (Hot Lava/GMetal Grey)
Good Scan Tool for Troubleshooting
I'm trying to source a good Scan Tool for doing troubleshoot/diagnostic checks, I'd like something that allows me to see data "real time" to be able to better troubleshoot engine control/sensor issues. Up to this point I have a fairly extensive knowledge of pre computor controlled engines/vehicles,...... but I'm trying to get myself more versed in troubleshooting modern vehicle control systems.
Would like to keep the investment price under $1000 (if possible)
hotrod1442 is offline   Reply With Quote
Old 03-20-2026, 09:32 PM   #2
bmacfrs
bmacfrs's Avatar
Drives: 2013 FRS
You want a bidirectional scanner. Check on Xtool D9S. Amazon or ebay. Bunch of videos on YouTube.
https://www.xtoolglobal.com/products...stic-scan-tool
Sent from my SM-S901U using Tapatalk
WIFE: "How can there be anything left to buy?"
bmacfrs is offline   Reply With Quote
Old 03-25-2026, 04:14 PM   #3
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
You could try a basic OBD Bluetooth scanner. I've got an OBD Link that's has somewhat helped in the past, but there's definitely better actual tools if you are serious about it.
If a picture is worth a thousand words, a model is worth ten thousand pictures.
Also: "Build Thread"
Old 03-26-2026, 11:28 AM   #4
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
Last year I bought a Gear Wrench scan tool from Amazon.ca.
I needed a two way scanner in order to monitor CVT fluid temps in our Crosstrek during a CVT fluid dump and fill.
It worked flawlessly. It’s just a dongle for the OBD port which connects via Bluetooth to their app on your device, in my case an iPhone. At only approx. 100CAD I couldn’t be happier.
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS-V/EvoX Brembos
Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms
235F/245R Conti ECS on TRD/Enkei wheels (street),
245/40 sq. ECF on 17x8 720Form GTF2 wheels (track)
Muskoka800 is offline   Reply With Quote
Codes marked Permanent - Scan tool does not erase?? P0102, P0113, P0017, P219A Sm1nts2escape Issues | Warranty | Recalls / TSB 1 07-06-2022 07:59 PM
Looking for help choosing a scan tool..autel or snap on or both? Newfoundland_scion_frs Other Vehicles & General Automotive Discussions 0 12-13-2016 09:07 AM
Aeroforce Scan Gauge DIE1000DEATHS Electronics | Audio | NAV | Infotainment 5 04-17-2016 05:53 PM
Scan tool ate my TPMS LS1M Software Tuning 4 07-27-2015 08:25 PM
Bluetooth OBD2 scan tool? Fast_Freddy Electronics | Audio | NAV | Infotainment 2 08-11-2013 10:34 PM
