Drives: Black with a rod knock
Codes marked Permanent - Scan tool does not erase?? P0102, P0113, P0017, P219A
I recently built a new engine for a 2013 that I got that had a spun rod bearing. When I started the car with the new engine I noticed after it warmed up it dropped to a low idle, the throttle became twitchy, wanted to stall and had the check engine light and slip light on. I put a scan tool on it and I have 4 codes p0102 - Mass or Volume air flow circuit low input, p0113 - Intake air temp circuit high input, p0017 - Crankshaft position camshaft position correlation bank 1 sensor b and P219a - Bank 1 Air-fuel imbalance. All four codes are marked permanent. When I delete them they are immediately there again once the scan tool rescans... Will these codes remove themselves when the issue is found and fixed or do I have to reflash the ecu or something else? I tried disconnecting
the battery and joining the power wires together to drain the capacitors in the ecu with no luck to drop the codes.
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Those codes are permanent specifically so they are not erased/battery disconnected to pass inspections.
The monitors need to pass for the ECM to clear them. |
| HELP! Cranks but won't start P0102 P0113 | Sum10clever | Issues | Warranty | Recalls / TSB | 2 | 09-05-2020 11:46 PM |
| Codes P0102 and P0113 | Alpha86 | Issues | Warranty | Recalls / TSB | 0 | 12-03-2019 09:38 AM |
| Engine Running Rich, P0102 P0108 P0113, and Misfires | Votlon | Engine, Exhaust, Transmission | 12 | 01-21-2017 03:38 AM |
| Scan tool ate my TPMS | LS1M | Software Tuning | 4 | 07-27-2015 08:25 PM |
| P0102, P0113, P2096 Engine code | Oburn | Engine, Exhaust, Transmission | 24 | 09-22-2014 04:30 PM |
