Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
What is the Star/Torx Bolt on the bottom of the manual trans
I recently learned its not the drain bolt (although some MTF came out).
Anyone know what it is? Or if I screwed up anything by opening it?
2014 BRZ: WRL Build (GP2) MCS, AP, Motec, race wiring harness, blah blah blah
2014 FRS: Similar WRL Build. Back up / parts / practice race car. 2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc. 1999 NB Spec Miata: 1.8 w/ all the goodies. 2022 CT5 Blackwing: Stock. |
not playing cards
| The Following User Says Thank You to Ultramaroon For This Useful Post: | GrandSport (08-21-2024) |
#3 | ||
https://www.nickslandrover.co.uk/wp-...wivels-025.jpg https://www.nickslandrover.co.uk/how...-detents-work/ ETA: Looks like ours would just fall out. A little scary because I think this means multiple gears can get engaged at once? I'm wondering if I should open it again and make sure its in there. I drove 2 sessions using gears 1-5 without an issue. But I had the same experience as you. No metal ball. I have a strain on my oil catch thing so I'd definitely see it.
not playing cards
Check my sig line for a link to @fireblaze's manuals. I've never been in that spot so I don't have anything more to offer. Seems odd to have a detent ball with no spring but that's what the IPB and the disassembly procedure specifies. Maybe it's an indexing/lock mechanism to allow only rotation of the shaft.
| Undid the wrong bolt for trans fluid (bottom bolt)... issues | GrandSport | Engine, Exhaust, Transmission | 1 | 08-26-2024 08:07 AM |
| How's the Manual Trans?? | BrZ_Good | BRZ Second-Gen (2022+) — General Topics | 37 | 12-05-2021 12:10 AM |
| What Manual Trans Fluid Do You Use? | McG86 | CANADA | 50 | 03-22-2020 08:19 PM |
| FRS/BRZ Manual Trans Fluid | shellslinger | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 131 | 11-02-2017 10:44 AM |
| POLL: Whiteline Top Vs SPC bottom vs Crash bolt | neilvosko | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 21 | 04-07-2017 09:57 PM |
