Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 11-29-2021, 02:00 PM   #1
BrZ_Good
Drives: '13 BRZ Ice Silver Metallic
How's the Manual Trans??
1st gen owner, thinking about making the swap. My syncro's started crunching at 13,000 in the 1st car, anybody having problems getting in gear?
BrZ_Good is offline   Reply With Quote
Old 11-29-2021, 02:09 PM   #2
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
The action is smoother, it’s harder to feel the synchros spinning up, I think mostly because they’re spinning up quicker. The shifting action is a bit more effortless and less notchy.
Old 11-29-2021, 02:33 PM   #3
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
What transmission oil? How often do you change it?
What usage?
timurrrr is offline   Reply With Quote
Old 11-29-2021, 03:38 PM   #4
vignesh
Engineer
vignesh's Avatar
Drives: WRB 2022 Subaru Brz
Anyone know if the MTech springs from gen 1 work or even considered an improvement for gen2? Not sure if Subaru changed those springs from gen 1
2022 BRZ WRB 6MT
2018 Camaro ZL1 1LE
vignesh is offline   Reply With Quote
Old 11-29-2021, 03:47 PM   #5
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
A quick look at the Subaru parts page shows the same springs in the transmission.
dragoontwo is offline   Reply With Quote
Old 11-29-2021, 06:31 PM   #6
Interceptor777
Interceptor777's Avatar
Drives: 2022 BRZ, 1999 "touge-spec" Miata
The trans is perfect for me. When cold, the shifts are just very slightly more stiff but still very easy. No trouble getting into gear, it's about 35F here on a cold day.
The action is precise and smooth, very easy to shift fast. Every gear is where it should be and it's just stiff enough that you feel confident smashing it but just soft enough that it's not a chore.
If you have to change trannies, would def recommend the swap over first gen. It feels similar to my friends 2018 but just refined and smoother in everyway.
Interceptor777 is offline   Reply With Quote
Old 11-30-2021, 12:07 AM   #7
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
If your crunching at only 13k the car isn't the problem.
Old 11-30-2021, 08:29 AM   #8
SpectreRT
SpectreRT's Avatar
Drives: Subaru BRZ
New transmission feels great. I'm personally getting used to how soft the clutch pedal is. Less feedback than I remember from my original BRZ. Not bad by any means, just different.
SpectreRT is offline   Reply With Quote
Old 11-30-2021, 01:32 PM   #9
Pat
Pat's Avatar
Drives: 2023 BRZ
While I understand why you say that, I don't necessarily agree. I, and many other experienced drivers, have had durability issues with these transmissions.
Old 11-30-2021, 01:51 PM   #10
s30series
Drives: 2015 BRZ Series.Blue
Weird, I had a warranty replacement transmission installed because of it.
s30series is offline   Reply With Quote
Old 11-30-2021, 02:21 PM   #11
Pat
Pat's Avatar
Drives: 2023 BRZ
Me too
Old 11-30-2021, 04:26 PM   #12
NikolaiCherepanov
Drives: 1997 BMW Z3 2.8, 2022 BRZ Premium
It is a bit soft but im not going to complain the clutch in my Z3 is the OEM original clutch from 1998 and I get a leg work out every time I drive it so the softer lighter clutch is a blessing
NikolaiCherepanov is offline   Reply With Quote
Old 12-01-2021, 12:03 AM   #13
s30series
Originally Posted by Pat View Post
Me too
I guess according to x808drifter the car wasn't the problem
So what was? The transmission?
Old 12-01-2021, 04:40 AM   #14
x808drifter
LMGTFY
Guess I need to physically type I was mistaken not just thank you guys for correcting me?
I mean shit. Out of all the 30+ twins on my island alone ZERO have had trans problems.
From stock to boosted.
I guess my sample size was too small.
BRZ/FRS AZ6 Manual Trans Upgraded Gearset RockySDS Engine, Exhaust, Transmission 169 09-15-2022 08:55 PM
What Manual Trans Fluid Do You Use? McG86 CANADA 50 03-22-2020 08:19 PM
FRS/BRZ Manual Trans Fluid shellslinger Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 131 11-02-2017 10:44 AM
Manual Trans 12k miles $750 OBO Amir Ghadiri Transmission and Driveline 4 05-23-2015 02:35 PM
Bump start in a manual trans? bayank BRZ First-Gen (2012+) — General Topics 11 02-16-2014 06:47 PM
