CANADA Canada
Old 03-01-2017, 12:16 PM   #1
McG86
Drives: Scion Frs
What Manual Trans Fluid Do You Use?
So I know this topic has been talked about quite a bit in the other sections but I want to get some info from my fellow Canadians. I have done it once already, switched over to Amsoil, but I don't think it did too much. I've been running it for a year now and I think my 2nd gear grind is getting worse. The winter makes second gear a real problem I basically have to skip second till the car has warmed up for a good 10 minutes. So my real question is, for those that changed their transmission fluid what has worked the best for you? And do you think at this point the problem might be just an issue with the trans?
Thanks in advance for any answers
McG86 is offline   Reply With Quote
Old 03-01-2017, 12:54 PM   #2
macaulay7
Drives: 2013 Subaru BRZ
I have the exact same problem and I now run Redline. Shifts smooth as butter when its hot but when cold the second gear crunches and grinds are unbearable.
When it first started getting cold I left the car with Subaru over night and they took it for a few test drives and told me it is just "normal Toyota gearbox noises" and "it must be you not pushing the pedal all the way down".
I occasionally look into it when I have the chance and the only thing I have found so far to minimize the crunches is to raise the clutch pedal back up (I had adjusted it down in the summer as per the DIY). Other then that I am in the same boat of double clutching or skipping second all together when its cold.
macaulay7 is offline   Reply With Quote
Old 03-01-2017, 01:07 PM   #3
daskaman
Drives: Burz
Redline, feels way better, especially when warm. That being said, the moment temps are below -5, crunchy crunchy unless I double clutch in 2nd
daskaman is offline   Reply With Quote
Old 03-01-2017, 02:26 PM   #4
brzzy
@anthonysestito
brzzy's Avatar
Drives: 2013 Sterling Silver Metallic BRZ
Subbed.
For the most part second gear is OK for me. At least I've found a way around it. However downshifts into second gear suck for the most part no matter what I do (feels more like clutch related than gear box) and my 6-5 downshifts crunch like a mofo no matter what I do post an OFT flash which is strange to me.
But subbed to know more about what other people in cold climates are using both on the street and track.
2013 BRZ LIMITED STERLING SILVER METALLIC
IG: @ANTHONYSESTITO
brzzy is offline   Reply With Quote
Old 03-01-2017, 02:40 PM   #5
ztrevs
ztrevs's Avatar
Drives: 17' CWP BRZ ------- 15' GLA45 AMG
Totaled.
Got to buy an auto now.
ztrevs is offline   Reply With Quote
Old 03-01-2017, 02:43 PM   #6
darko
Drives: RAVEN FRS
A while ago I read a thread on here that the engineer who designed the gearbox knew about the issue. Something to do with performance vs lose gear gap. As cold weather expands and contracts the metal makes it difficult to actuate it into gear
Also how many Km's are you guys changing the fluid?
found the link: http://www.ft86club.com/forums/showthread.php?t=31929
darko is offline   Reply With Quote
Old 03-01-2017, 02:45 PM   #7
brzzy
@anthonysestito
brzzy's Avatar
Originally Posted by ztrevs View Post
Totaled.
I thought we were talking about auto gearboxes?
Jks
IG: @ANTHONYSESTITO
Old 03-01-2017, 02:54 PM   #8
daskaman
Drives: Burz
So far 13,000 km from new. Metal shavings present, but nothing too crazy compared to most new cars that I see.
Old 03-01-2017, 03:20 PM   #9
wparsons
wparsons's Avatar
Motul Gear 300 for me in both the gearbox and diff (same fluid, not running the 300LS in the diff since it's not a clutch LSD).
I still get occasional 2nd gear crunches when cold, but it's not every shift even in the dead of winter.
flickr
Old 03-01-2017, 08:52 PM   #10
roddy
roddy's Avatar
Drives: '13 Ultramarine
Pentosin MTF2. I've tried a few different fluids, and for my FR-S, it seems to work best. I have not tried Motul, or Redline's MT-85. I've had my car since June 2012, it has over 100,000kms on the clock, and it is my daily driver year 'round in Southern Ontario.
Most car manufacturers put Canada in the "severe service" category for maintenance scheduling...with that in mind, the recommended interval for manual transmission fluid changes is 24,000kms/2 years. I change mine every spring.
Old 03-02-2017, 11:53 AM   #11
McG86
Drives: Scion Frs
Just about everyone raves about Motul gear 300 but I was reading in one of the threads and a member said it was horrible to drive in the cold with it. I was thinking that was going to be my next fluid to try though.
Old 03-02-2017, 11:56 AM   #12
McG86
Drives: Scion Frs
Do you find that it still grinds at all in the cold? or downshifting is hard? I mean I've only had this trans fluid in for a year/ 14,000 km so I didn't think it would be this bad
Old 03-02-2017, 12:00 PM   #13
jasonojordan
Drives: 2013 satin white brz limited
I have motul gear 300 in mine and on cold starts 1st to 2nd is very very difficult. Once warm is gets much better. Im planning to try out https://www.amazon.com/dp/B002INX20C...N5VX4S7G&psc=1
For my next transmission fluid.
jasonojordan is offline   Reply With Quote
The Following User Says Thank You to jasonojordan For This Useful Post:
McG86 (03-02-2017)
Old 03-02-2017, 06:15 PM   #14
roddy
roddy's Avatar
Only on the first shift or 2 when it is really cold...I've never had a problem downshifting. With any fluid, the trans should have some time to warm up before the best shift qualities are present. This fluid will "warm up" faster vs. stock due to the lower viscosity. It will be fine for a daily driver...if you plan on tracking the car, it may be safer to stay with the recommend 75W90.
I tried Redline MT-90...it was an improvement over stock, but the crunch was still there (even with a fair bit of warm up and some gentle driving).
The Following User Says Thank You to roddy For This Useful Post:
McG86 (03-02-2017)
FRS/BRZ Manual Trans Fluid shellslinger Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 131 11-02-2017 10:44 AM
Manual Trans./Diff. Fluid Change.?. westmansweed Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 13 07-15-2015 08:02 AM
Auto Trans Fluid Drain & Refill ProTekk Engine, Exhaust, Transmission 4 09-08-2013 06:43 PM
Change trans fluid thru dipstick bigsley18 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 07-18-2013 10:16 AM
Trans/Diff Fluid. DanoFA20 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 01-11-2013 03:11 PM
