View Poll Results: Camber Bolt used ? max camber achieved with that bolt?
OEM 14 mm Top Crash, - 1.0 4 12.12%
OEM 14 mm top Crash, - 1.5 2 6.06%
Whiteline Top 16 mm, - 1.5 5 15.15%
Whiteline Top 16 mm, - 1.0 2 6.06%
Whiteline Top 16 mm, - 1.5 6 18.18%
Whiteline Top 16 mm, - 2.0 2 6.06%
SPC 81305 bottom 14 mm, - 0.5 1 3.03%
SPC 81305 bottom 14 mm, - 1.0 1 3.03%
SPC 81305 bottom 14 mm, - 1.5 5 15.15%
SPC 81305 bottom 14 mm, - 2.0 5 15.15%
Voters: 33. You may not vote on this poll
Old 11-24-2016, 05:03 PM   #1
neilvosko
neilvosko's Avatar
Drives: Hyper Blue BRZ
POLL: Whiteline Top Vs SPC bottom vs Crash bolt
There is a lot of different options for camber bolts and lots of different info all over the forum, so i am curious to curate the community results into a single poll, limited to single camber bolt change.
please select the bolt you changed and max negative camber you achieved:
note, the first option for whiteline top is 0.5 and spc 81280 can also be used in place of whiteline
thank you all in advance
neilvosko is offline   Reply With Quote
Old 11-24-2016, 09:22 PM   #2
bfrank1972
Drives: 2013 FR-S Argento
hmm, why whiteline top vs spc bottom? whiteline cam bolts are relabeled spc bolts as far as i know. how much camber adjustment do you want? a little? crash bolts are fine. need a bit more? spc cam bolts in the top holes can give you up to -1.5 in the front. add cam bolts on bottom and you can roughly double that.
Sent from my SM-N920V using Tapatalk
bfrank1972 is offline   Reply With Quote
Old 11-24-2016, 11:23 PM   #3
Cartman
Cartman's Avatar
Drives: 10 Series Scion FR-S
SPC bottom with OEM 14mm crash bolt top = -2.4 with 1" drop.
Cartman is offline   Reply With Quote
The Following User Says Thank You to Cartman For This Useful Post:
neilvosko (11-24-2016)
Old 11-24-2016, 11:27 PM   #4
neilvosko
neilvosko's Avatar
The spec kit is 14 mm for the 14 mm bottom
The white line is a 16 mm for the top
Both are eccentric
Oem bottom is not eccentric 14 mm
Old 11-25-2016, 09:51 AM   #5
Calum
That Guy
Drives: 2013 asphalt FRS MT
Aren't the SPC and Whiteline sourced from the same manufacturer? They look identical.
Old 11-25-2016, 10:06 AM   #6
neilvosko
neilvosko's Avatar
here is the summary of my research on the bolts
OEM crash bolt is same as the bottom hole 14 mm bolt
Whiteline 416 is essentially a SPC 81280 bolt you can get for 25 bux, its a 16 mm bolt designed for the top 16 mm slot
SPC 81305 is same as 81260 bolt, which is a smaller 14 mm bolt designed for the bottom slot
single digit accounts on the forum indicating -1.2 to -1.5 range adjustment with top whiteline/spc bolt (about -1.1 with oem crash bolt)
not much info on the SPC bottom bolt only, maybe this poll will shed some light, but a few posts about using SPC 81260 on bottom and 81280 on top to get -2.4 to -2.5 negative camber.
The Following 2 Users Say Thank You to neilvosko For This Useful Post:
MJones_RB (11-30-2016), ruturaj001 (05-16-2023)
Old 11-30-2016, 06:55 PM   #7
MJones_RB
MJones_RB's Avatar
Is this a one time, set-it-and-forget-it camber adjustment for lowering your car, or a trackside dialing-in application? If it's for dialing in, I'd go with the option that can be done without removing the wheels. Saves time and energy, like top hats with camber adjustment and adjustable rear control arms.
MJones_RB is offline   Reply With Quote
Old 11-30-2016, 09:05 PM   #8
OND
OND's Avatar
Drives: 2023 BRZ
I got SPC 81280 (16mm) on top holes with -1.3 camber. The alignment shop took longer than usual to install the bolts, so Im not sure if that part is a perfect fit, but they made it work somehow.
OND is offline   Reply With Quote
Old 11-30-2016, 09:56 PM   #9
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
SPC bottom with oem crash top for -2.4°
JazzleSAURUS (12-22-2016)
Old 12-06-2016, 05:47 PM   #10
bhmax
Drives: 13 BRZ, 17 Focus RS
Earlier this year I used the bottom (crash) bolt in the top and a 14mm camber bolt in the bottom to get -1.2 on stock suspension. I wanted to get a bit more negative, so I put a 16mm camber bolt in the top. I just got the alignment done and was only able to get -.7. Seems a bit strange, but I guess maybe you can get more slop with the crash bolt to get more negative? I don't currently want to do camber plates so I may have to look into slotting if I want to get more on stock springs.
bhmax is offline   Reply With Quote
Old 12-20-2016, 11:07 PM   #11
neilvosko
neilvosko's Avatar
it seems like we need a larger sample size for a more meaningful answer
Old 12-21-2016, 01:20 PM   #12
strat61caster
strat61caster's Avatar
Whiteline 16mm, about -1.1 degree (up from -0.4 OE)
If you want maximum performance on a budget, 14mm camber bolt on bottom, swap the bottom bolt into the top hole. IMO the only reason to not do this is for complying to a set of rules, which will typically say 'OE crash bolts only' (SCCA) or if you have fears about slippage, which seem unfounded to me, haven't heard of anything slipping and causing issues, if driven aggressively alignment should be checked on a semi-regular basis anyway.
I may be looking into the 14mm SPC bolt to get additional camber after camber plates (currently maxing about -3.6) time will tell.
ineedyourdiddly
Old 12-21-2016, 02:16 PM   #13
max20s14
Drives: 14' Raven M/T - 02' is300
got -1.7 camber, 0 toe in the front with my spc bolts in the bottom hole
max20s14 is offline   Reply With Quote
Old 12-21-2016, 03:12 PM   #14
neilvosko
neilvosko's Avatar
thats impressive, bottom bolt is producing a little more neg camber
OEM Crash Bolts, top and bottom Fish Eagle Tracking / Autocross / HPDE / Drifting 14 12-16-2016 09:45 PM
Whiteline KCA416 or Crash Bolt for slotted upper strut? FR-S Matt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 24 01-31-2014 04:10 PM
Crash bolt nut size qoncept Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 06-03-2013 08:38 PM
Crash bolt question ayau Tracking / Autocross / HPDE / Drifting 8 08-17-2012 02:22 PM
BRZ crash bolt same as Impreza lower strut bolt? xwd Tracking / Autocross / HPDE / Drifting 0 07-05-2012 01:19 PM
