Old 08-19-2024, 03:55 PM   #1
GrandSport
GrandSport's Avatar
Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
Undid the wrong bolt for trans fluid (bottom bolt)... issues
Man, what a day. I was sick just starting to get better (but far from 100%) so I went to the track. I decided to do a fluid swap for some reason, idk why. I had 90 min to kill so why not.
First, I drained using the bolt underneath the transmission, not the side. It has a torx/star pattern. I didn't notice anything strange or any springs pop out or anything, but I can't figure out if I screwed up anything (Miatas, for example, definitely have "do not open" bolts)
Then I put the Miata MTF in there. Doh! Saw that after 2 sessions. Drain and refill. Looked really thin and almost gray- like muddy water kinda. I'm not worried about the wrong fluid causing damage (it was MTL, so it's fine), but the color on it was disturbing for 45 min of driving. Made me concerned I screwed something up with that bolt and metal was shearing into the oil or something.
But it felt fine.
2014 BRZ: WRL Build (GP2) MCS, AP, Motec, race wiring harness, blah blah blah
2014 FRS: Similar WRL Build. Back up / parts / practice race car.
2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc.
1999 NB Spec Miata: 1.8 w/ all the goodies.
2022 CT5 Blackwing: Stock.
GrandSport is offline   Reply With Quote
Old 08-26-2024, 08:07 AM   #2
Tozerman
Drives: 2016 BRZ SE
I did exactly the same thing last year.
https://www.ft86club.com/forums/showthread.php?t=153051
There is a ball that goes in there but as far as I can tell the little torx bolt is used for assembly only. I have since noticed that 2nd gear can be quite notchy when cold but is perfect when warmed up.
Regarding used the complete wrong fluid in there, I doubt that it would cause any major issues.
Tozerman is offline   Reply With Quote
Perrin Oil Cooler - Mocal Plate Spacer Bolt - Damn Bolt Gopherboy6956 Engine, Exhaust, Transmission 16 11-23-2017 11:56 AM
POLL: Whiteline Top Vs SPC bottom vs Crash bolt neilvosko Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 04-07-2017 09:57 PM
BC Racing BR top bolt issues austin_kw Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 09-20-2016 06:19 PM
Camber bolt + suspension bolt torque settings LostSalad DIY (Do-It-Yourself) Guides 3 05-09-2016 09:29 AM
BRZ crash bolt same as Impreza lower strut bolt? xwd Tracking / Autocross / HPDE / Drifting 0 07-05-2012 12:19 PM
