Old 10-23-2023, 10:19 AM   #1
nickmerronesucks
Ned flanders
nickmerronesucks's Avatar
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
Advice on figuring out what I am tuned on
Bought a 14 BRZ, Found out it has some sort of launch control. Not sure how to tell.
Problem being is FFS or LC is being enabled via the clutch switch when i go WOT and go to clutch kick(vise versa).
I don't know the history. The car is stock other than suspension, if i buy an OFT can I just start new? or since this thing has a file of some sort how do I determine what it was tuned with?
797Performance.com
nickmerronesucks is offline   Reply With Quote
Old 10-23-2023, 07:14 PM   #2
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
I don't think OFT is going to let you start new without some special sauce mixed into the process, or if it does it might cause worse problems. It would probably let you at least read the calid to see if someone messed with it, but I think there are probably other readers that are cheaper.
Subaru dealership can probably check to see if it's been tuned as well. They won't be able to tell you how though.
If a picture is worth a thousand words, a model is worth ten thousand pictures.
Also: "Build Thread"
The Following User Says Thank You to Spuds For This Useful Post:
nickmerronesucks (10-24-2023)
Old 10-24-2023, 10:08 AM   #3
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Ecutek typically has map control and you can adjust launch control RPM with cruise control stock. Hold launch control and press up/down on cruise control stock and if it adjusts RPM then ecutek. Any time running you can pull cruise stock towards you and hold for 1-2 seconds. Map control will come up and RPM will go anywhere between 1000, 2000, 3000, 4000 which indicates what map(1,2,3,4)
OFT has no map control and launch control is fixed and cannot be adjusted without a ECU flash.
The Following 2 Users Say Thank You to RToyo86 For This Useful Post:
Spuds (10-24-2023), Teseo (10-25-2023)
Old 10-24-2023, 02:36 PM   #4
nickmerronesucks
Ned flanders
Awesome I will try to do that with the car running to try & see.
Local dealership doesn't want to get involved.
797Performance.com
Old 10-25-2023, 10:43 PM   #5
Teseo
Drives: frs
Like wise
Old 10-26-2023, 12:42 AM   #6
RToyo86
RToyo86's Avatar
Good luck.
Can also check how launch control is activated. OFT and ecutek are little different.
OFT it's always on even in neutral so long as you are stopped. Active with any amount of throttle %.
Ecutek requires clutch depressed and full throttle. Cannot remember if being in 1st gear matters.
Old 10-26-2023, 10:39 PM   #7
callisto
Drives: 2019 Subaru BRZ
If the cruise control 1/2/3/4 step fails, then it might not be Ecutek at all. You can try getting a Tactrix adapter and download the current tune from the car. Tactrix will tell you what your ZA1Jxxxx is, and then you’ll have the tune file to upload to ask more questions about — and/or, you could then dig up the stock ZA1Jxxxx ROM for your car and flash it with Tactrix to put it back to stock. Or you could consider introducing OFT instead of Tactrix, and the OFT might accept your current ROM as your ‘original’ ROM, which would let you update it to latest or whatever.
(But. Paying a tuner to revert the car to stock and start over is probably simpler, though!)
callisto is offline   Reply With Quote
Help figuring out my brake problem Jfheisenberg Suspension | Chassis | Brakes -- Sponsored by 949 Racing 19 05-10-2022 03:07 PM
Need help figuring something out Jrevans1992 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 09-30-2016 01:56 PM
E85 tuned with OFT advice Bakchoii Software Tuning 5 09-07-2015 12:45 PM
Need help figuring out if I can afford an FR-S. BrianFRS Scion FR-S / Toyota 86 GT86 General Forum 57 03-31-2014 09:55 PM
Need help figuring our how to remove these pieces. !! Cowbun Cosmetic Modification (Interior/Exterior/Lighting) 12 10-17-2012 06:44 PM
