Old 04-04-2022, 01:59 PM   #1
Jfheisenberg
Jfheisenberg's Avatar
Drives: 2015 BRZ Series Blue WRB
Help figuring out my brake problem
Hi everyone - Im having a problem with my brakes on my BRZ.
When i press the brakes the car vibrates, i can feel the vibration on the brake pedal, on the steering wheel and even passengers can feel this vibration. The more high speed braking i do, the more the vibration i notice.
At low speeds, i can feel some tapping on the brake pedal during braking, but there is no vibrations.
Tires/wheels are new, and were mount/balanced. Today i replaced the front rotors and pads thinking my old rotors could warped. Issue is still there, same vibration when pressing the brakes and even worse when braking at high speeds.
Any suggestions what could be?
Jfheisenberg is offline   Reply With Quote
Old 04-04-2022, 02:13 PM   #2
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Rear rotors would be my next guess.
The Following 2 Users Say Thank You to x808drifter For This Useful Post:
AJ32162 (04-04-2022), jflogerzi (04-21-2022)
Old 04-04-2022, 02:24 PM   #3
Jfheisenberg
How the rear rotors affect the front, i dont understand this part. The mechanic was thinking the wheel hub, but that is very rare case
Old 04-04-2022, 03:05 PM   #4
86league
Drives: '13 BRZ Limited
I recently had a similar issue. It turned out to be the hub. I replaced rotors/pads and the problem was still there. Replaced the hub/wheel bearing and the vibration/brake shudder went away. The Subaru parts guy commented that they had been seeing a LOT of wheel hubs going through their department lately.
Mine got worse with repeated/increased braking (increased brake/hub temperature?).
I can't say it is the hub in your case, but I'm not sure I'd discount it either. Mine didn't show any of the typical signs of a failure (noise/play).
86league is offline   Reply With Quote
The Following User Says Thank You to 86league For This Useful Post:
Jfheisenberg (04-04-2022)
Old 04-04-2022, 03:18 PM   #5
x808drifter
LMGTFY
Ignore that.
Didn't even think about the steering part.
Old 04-04-2022, 03:22 PM   #6
Jfheisenberg
Did you replaced only the front driver side wheel hub? Did you use OEM parts?
In my case, the vibrations are getting worse by day, i try to drive slow and brake slowly in the meantime if i have to use the car.
Old 04-04-2022, 04:49 PM   #7
86league
At first I did only replace the front/drivers side as it seemed to be the most obvious problem. I used a hub from a local auto parts store, not OEM. Necessary since I did the swap at 9PM on a Saturday.
On Monday, I called Subaru of America and they gave me a $500 parts/service credit which covered 2 new OEM hubs, so I replaced the passenger side as well.
The Subaru parts counter guy did half joke that I might be better off leaving the parts store brand hub on the car.
Old 04-04-2022, 05:22 PM   #8
Jfheisenberg
So you fixed by replacing all 4 wheel hubs? Im thinking on just buying the front wheel hubs like this one
Or would you recommend aftermarket ones instead
Old 04-04-2022, 05:52 PM   #9
86league
My issue went away with replacing just the one front hub. I don't think there was really anything wrong with the passenger side front hub, but I got the parts for free, so I replaced it anyway. I had a rear hub fail at 12,500 miles and this front hub "failed" at 15,000 miles. I just didn't have much faith in the original hub and preferred to replace it for peace of mind.
I can't speak to the quality of aftermarket vs. OEM. Sorry. The link you sent is the same part # I put on my car.
https://parts.ewingsubaruofplano.com...8373CA000.html
Old 04-18-2022, 05:07 PM   #10
Jfheisenberg
I replaced the front driver side wheel hub and part of the problem went away.
The other problem was my rear rotors, the inner side of the rotors were falling apart. It was tricky because the outer side of the rear rotor looked fine, but all the signs pointed at the rear rotors so they were replaced.
Old 04-18-2022, 07:50 PM   #11
Joon525
Joon525's Avatar
Drives: 2016 BRZ
Can you elaborate on that? Was it so worn down it that there was barely any metal left?
Joon525 is offline   Reply With Quote
Old 04-20-2022, 01:49 PM   #12
Jfheisenberg
Old 04-20-2022, 06:54 PM   #13
SCFD
I don't think I've seen rotors wear like that before. What was the brand of the rotors?
SCFD is offline   Reply With Quote
Old 04-26-2022, 06:08 PM   #14
Jfheisenberg
Stop tech, lasted < 2 years
Brake fluid problem WNDSRFR Issues | Warranty | Recalls / TSB 24 08-10-2021 10:18 PM
Valenti 4th brake wiring problem andrewtgg Cosmetic Modification (Interior/Exterior/Lighting) 14 08-21-2017 08:10 AM
Need help figuring something out Jrevans1992 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 09-30-2016 12:56 PM
Brake pad problem (CL Brakes RC5+) Tor Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 09-13-2016 06:32 PM
Rear brake problem fender9530 Issues | Warranty | Recalls / TSB 18 03-15-2013 07:52 AM
