Old 09-22-2016, 06:28 PM   #1
Jrevans1992
Drives: 2013 subaru brz limited
Need help figuring something out
Soooooooooooooo for some reason my abs light and my traction control light come on after a bit of driving but not when i immediately start the car. it could be a speed sensor(on my guess) but could it be something else? the car doesnt drive any differently or anything but id rather not have lights on my dash. it also prevents me from using my cruise control or sport mode.
Thanks in advance everyone!
Jrevans1992 is offline   Reply With Quote
Old 09-22-2016, 06:30 PM   #2
new2subaru
Weight Weenie
Drives: 15 FR-S
Mine do that too on occasion
The Following User Says Thank You to new2subaru For This Useful Post:
go_a_way1 (09-22-2016)
Old 09-22-2016, 06:34 PM   #3
Jrevans1992
but this is everytime i drive haha. and the faster i go the quicker itll come on. i havent bothered with it too much since my car isnt feeling different but thatll kick me in the ass later im sure
The Following User Says Thank You to Jrevans1992 For This Useful Post:
new2subaru (09-22-2016)
Old 09-22-2016, 06:39 PM   #4
wbradley
Sarcastic SOB
wbradley's Avatar
Do you have any mechanical mods such as a header or maybe an intake? Larger diameter wheels in the back than front?
Do you have a way to get an OBDII scan done?*
Do you have a check engine light? (It appears not).
*most likely will tell you the cause, maybe a sensor or something.
And lastly, if you are within warranty, just take it to the dealer.
You might have an issue with a sensor, possibly ABS/wheel speed sensor.
I had issues with my tune not cancelling the check engine light for one cat removed. Also, had a dirty MAF sensor. When the CL light went on, so did the traction light (but not ABS) and also cruise would not operate.
Old 09-22-2016, 06:42 PM   #5
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Me too, but only when I go fast around corners
Old 09-22-2016, 07:10 PM   #6
geezerbrzeezer
Geezer
Drives: 2016 Subaru BRZ Sport Tech
I'm about to make what is going to seem, on the surface, the stupidest post of the day, and possibly of this forum's existence:
Check your brake fluid level.
geezerbrzeezer is offline   Reply With Quote
The Following User Says Thank You to geezerbrzeezer For This Useful Post:
humfrz (09-22-2016)
Old 09-22-2016, 07:19 PM   #7
new2subaru
Weight Weenie
Drives: 15 FR-S
Actually, I think that's a very good suggestion.
Old 09-22-2016, 07:28 PM   #8
humfrz
NO_NO_NO! ......that is waaaay too simple, we are only on page 1, we must make a bigger deal out of this ......
humfrz
The Following 3 Users Say Thank You to humfrz For This Useful Post:
EastBayCanuck (09-30-2016), go_a_way1 (09-28-2016), wparsons (09-22-2016)
Old 09-22-2016, 11:26 PM   #9
MrDinkleman
Drives: 2016 Oceanic, "base" model
Staggered wheel/tire sizes?
MrDinkleman is offline   Reply With Quote
Old 09-23-2016, 05:55 AM   #10
Sounds like "limp mode" to me. There is usually a CEL involved as well but not always. If it is then it could be jus about anything.
As asked, any mods? Intake, header, anything?
Old 09-23-2016, 07:00 AM   #11
geezerbrzeezer
Geezer
humfrz
You're right. Let's try this again.
Rent a hanger. Disassemble your car completely - the scene should look like a Mayday NTSB crash investigation. Analyze the flight data and voice recorders for clues. Reassemble your car. Check brake fluid.
The Following 2 Users Say Thank You to geezerbrzeezer For This Useful Post:
go_a_way1 (09-28-2016), humfrz (09-23-2016)
Old 09-28-2016, 06:37 PM   #12
Jrevans1992
actually its full cause i was wondering about it.
i think it could be a speed sensor though since its delayed though. and no mods totally stock to those asking.
Old 09-29-2016, 10:46 AM   #13
No CEL?
Old 09-30-2016, 12:50 PM   #14
Jrevans1992
No CEL?
No. And the lights only come on after driving a bit. it comes on sooner the faster I drive( like on a highway compared to driving on backroads.
Need help figuring out if I can afford an FR-S. BrianFRS Scion FR-S / Toyota 86 GT86 General Forum 57 03-31-2014 08:55 PM
Need help figuring our how to remove these pieces. !! Cowbun Cosmetic Modification (Interior/Exterior/Lighting) 12 10-17-2012 05:44 PM
