Old 08-22-2012, 01:57 PM   #1
Brzer
Drives: BRZ, 2011 Outback 3.6R
Oil extractor oil change.
Thought I would let everyone know that I just changed my oil using a dipstick oil extractor. I also changed out the oil filter. I put in 5 and 5/8 quarts to be just shy of the fill line on the dipstick. Based on what others have been reporting, I don't think the method could have left much if anything behind. I used the West Marine 6.9 quart extractor. Worked great!
Brzer is offline   Reply With Quote
The Following 4 Users Say Thank You to Brzer For This Useful Post:
avusblue (08-23-2012), Bonburner (08-22-2012), DAEMANO (03-30-2014), TemeCal (08-22-2012)
Old 08-22-2012, 02:42 PM   #2
TemeCal
Drives: 86
Those extractors are very useful. I use them on my boat and offroad vehicles. For my cars though, I almost find the fumoto valve to be an easier solution.
TemeCal is offline   Reply With Quote
The Following User Says Thank You to TemeCal For This Useful Post:
AJUSA.com (08-23-2012)
Old 08-23-2012, 03:10 PM   #3
Brzer
But with the extractor method there is no need to worry about a car falling on top of you. Only if I had a pit in my garage would I not use this method given how fast and easy it was.
The Following User Says Thank You to Brzer For This Useful Post:
TemeCal (08-25-2012)
Old 08-23-2012, 03:22 PM   #4
mach330
Drives: Ultramarine frs
I have one as well. Been using UT on my bimmers (until they got rid of dipstick!). Love the fact that fr-s/brz oil filter is also on top. No more kidding the car for me.
Tap'd from my G-Nex
mach330 is offline   Reply With Quote
Old 08-24-2012, 02:33 AM   #5
Lytheum
Drives: 2013 BRZ Premium 6MT
i may have to look into one of these. i live in an apartment and this would be great. i could change it in my garage here and no one would even know!
2013 Subaru BRZ Premium 6MT -STOCK!
Lytheum is offline   Reply With Quote
Old 08-24-2012, 02:44 AM   #6
GrimmSpeed
GrimmSpeed's Avatar
Drives: '13 BRZ, '12 WRX
Send a message via AIM to GrimmSpeed Send a message via MSN to GrimmSpeed
Make sure you got that tube all the way down...want to make sure you get all that nasty stuff at the bottom of the barrel
Justin Grimm
GrimmSpeed is offline   Reply With Quote
The Following 2 Users Say Thank You to GrimmSpeed For This Useful Post:
AZP Installs (12-01-2012), meeks (08-25-2012)
Old 08-28-2012, 12:37 PM   #7
jdub512
jdub512's Avatar
Drives: Whiteout SCION FR-S
Do you take the extractor with the oil in it to say Autozone or some place that takes used oil or do you empty it out in another container first?
jdub512 is offline   Reply With Quote
Old 08-28-2012, 01:47 PM   #8
Brzer
I emptied it into containers for curbside recycling. You just need to be careful not to tip the container upside down or it can damage its ability to hold a vacuum.
Old 08-28-2012, 04:21 PM   #9
Turbowned
Turbowned's Avatar
They recycle waste oil curbside for you?? Damn!
Old 08-28-2012, 11:50 PM   #10
bryan
bryan's Avatar
Drives: Lots of Toyotas
I did the first oil change on my car last night. I tried to siphon the oil using an oil extractor and it didn't work!
The extractor is how I normally perform oil changes, however, the extractor tube wouldn't go far down enough to siphon all the oil from the FA20. I got about 1.5 litres before it stopped sucking oil. I wrestled with the tube for a while to see if I could get it down lower into the pan but no luck. I had to lift the car and resort to draining the oil from the pan instead.
What's going on? I was using the smallest extractor tube I had too. I'm positive it wouldn't go any further. Somebody, help me out.
bryan is offline   Reply With Quote
Old 08-29-2012, 06:00 AM   #11
Shiny
Drives: 05 Ford F150 Scrow
I don’t recommend this for the first oil change.
I don’t think you will get all the junk out of the sump (metal, casting junk…). Witch all how do the first oil change early do it to get rid of all that junk out.
If you ask me I believe the first 2 to 3 oil changes should be throe the sump drain plug. And before tightening the pug I would pour ½ to 1 quart of oil to be sour that all the old oil and junk is out. Plus I would use a filter magnet to.
Shiny is offline   Reply With Quote
Old 11-28-2012, 01:25 PM   #12
microbionic
microbionic's Avatar
Drives: 2013 Subaru BRZ
what extractor did you use? .. i have been looking for one that works with our vehicles
microbionic is offline   Reply With Quote
Old 11-28-2012, 03:42 PM   #13
Brzer
See my first post. Bought it at West Marine.
Old 11-28-2012, 05:25 PM   #14
Daless2
I've used a MityVac Oil Extractor for more then 30 years and have never had an internal engine problem.
1984 Mercedes 300D 346,000 miles
1997 Jeep Wrangler 147,000 miles
1992 Toyota Mini Van 219,000 miles
2003 Mercedes C230 Kompressor 113,00 Miles (Doesn't even have an oil drain plug on engine.)
And now a 2013 FR-S 2,750 miles
I think far more important to engine longevity is frequency of oil changes. I use only manufacturers filters and Mobil 1 on everything but the diesel.
I change religiously ever 5,000 miles.
Perhaps it's just luck but the extractor and this regiment works for me and a lot easier then getting under some of these vehicles.
Daless2 is offline   Reply With Quote
3,000 mi oil-change prest1ge Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 38 10-29-2012 07:13 PM
First Oil Change Jehuty77 CANADA 14 08-09-2012 11:54 PM
Took my car in for an oil change... joshua BRZ First-Gen (2012+) — General Topics 25 08-04-2012 09:32 PM
When to do your first oil change, and why... MrBodyMassage Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 07-17-2012 07:43 PM
Do you change your own oil? If so, why? SteelReign Other Vehicles & General Automotive Discussions 76 04-15-2012 04:44 AM
