Old 04-07-2023, 03:33 AM   #1
StevetS
StevetS's Avatar
Drives: 2013 FRS
This peculiar noise started at the same time I lost power.
Hey everyone, I’m wondering if you can help me identify this rattling noise under my car.
I put on the Edelbrock supercharger about a month ago and it’s been running absolutely phenomenally lately. I have upgraded injectors and a fuel pump as well as a over pipe back exhaust from counterspace garage. I drove to the gym yesterday and the car felt perfect, however, when I drove back from the gym, it felt like the car had no supercharger at all, it felt very laggy and under powered.
I drove the car this morning to check if the symptoms were still there, and they came back more when the car warmed up, which makes me think it’s coil packs, however, this sound started when I was leaving the gym, so the car essentially lost power, and this noise started on the same trip, which is very peculiar. I’m pretty familiar with cars and mechanical issues, but I haven’t heard this noise before I do have the stock exhaust manifold on the car right now, so maybe it has something to do with that. I also have an Exedy OEM clutch on the car as well which I was going to replace when it died but the noise kind of sounds like it’s coming from the clutch area or from the exhaust manifold area but I’m not sure. The sound is a lot more noticeable when getting low to the ground next to the car than it is from the engine bay.
Any help identifying this noise would be greatly appreciated.
https://player.vimeo.com/video/815552140?h=c7793d4bd8
StevetS is offline   Reply With Quote
Old 04-07-2023, 04:12 AM   #2
tomm.brz
Drives: brz 2017 hksv2
i think it s a cat that got destroyed by yhe sound of it....
is the sound rpm-related? or sounds always random and rattling like amarmbles in the exhaust?
Since you have negative trims and super rich afr... i would lean in this direction of the cat and maybe put down header and front pipe to check them..
coil pack would give at least some error or misfire in logs
sound similar and was the cat
Old 04-07-2023, 04:24 AM   #3
tomm.brz
Hit the exhaust manifold and front pipe with a rubber hummer...
if it chunks it s the cat
Old 04-07-2023, 11:55 AM   #4
StevetS
StevetS's Avatar
Drives: 2013 FRS
100% that is the exact same noise I am hearing. Very interesting, at least now I know what a failed catalytic converter sounds like. You were dead on again! I am looking for a used set of headers locally and if I can’t find a decent deal. I will buy a new set.
Old 04-07-2023, 12:01 PM   #5
tomm.brz
first try to understand if i m really right
and if it s the one in the header or the one in the front pipe that detached
The Following User Says Thank You to tomm.brz For This Useful Post:
Clipdat (04-07-2023)
FRS lost substantial power and exhaust quieter? pimmorg Engine, Exhaust, Transmission 11 06-23-2020 02:31 PM
Muffler Delete Lost POwer????? mr.brz1234 Engine, Exhaust, Transmission 16 09-21-2017 05:50 PM
Strange metallic vibration noise started dumbforcrumbs Issues | Warranty | Recalls / TSB 1 02-02-2017 09:28 PM
Cold Weather Transmission Peculiar PMPB CANADA 4 10-12-2013 10:52 AM
Lost power in 1st gear and a bit of 2nd bear89103 Engine, Exhaust, Transmission 6 07-28-2013 05:32 AM
