CANADA Canada
Old 10-11-2013, 03:21 PM   #1
PMPB
Drives: BRZ Sport-tech
Cold Weather Transmission Peculiar
With the recently pretty dang cold mornings, are any of you experiencing nasty transmission shifting?
Pretty much, no matter how slow/fast I shift, the tranmission first 5-10 minutes in the morning is so notchy it's to the point where i'd call it a 'mini-grind' in every single gear.
Pulling from 1st to 2nd, it's almost like I can feel each synchro catch and then a nice little thunk into gear that makes me wince. Pretty much the same thing into the next 5 gears. It's almost like the cold transmission fluid glues all the synchros together so that they don't really do anything to mate moving parts.
Honestly, I'm not really sure how everything in there works.... but it doesn't feel nice until everything is warmed up. Before setting off in the morning, I let the engine idle until the revs come down.
PMPB is offline   Reply With Quote
Old 10-11-2013, 05:20 PM   #2
Rossman
Rossman's Avatar
Drives: '22 BRZ, '17 BRZ (prev '13 FR-S)
Yeah, it happens. I get the same shit in my 6speed Versa.
Rossman is offline   Reply With Quote
Old 10-11-2013, 07:35 PM   #3
roddy
roddy's Avatar
Drives: '13 Ultramarine
Changing the fluid helped mine a lot.
Old 10-11-2013, 10:29 PM   #4
PMPB
Is there a fluid that SOC or your local dealership will accept as equivalent or better than the stock fill, in terms of maintaining the warranty?
Old 10-12-2013, 09:52 AM   #5
Suberman
Drives: Subaru BRZ Sport Tech Satin White
Only 1/2 shift exhibits a crunch on cold mornings on my car. Because this stops as soon as some heat gets into the transmission it can't be faulty synchros.
I'm waiting for further mileage accumulation before getting excited.
Some transmissions, particularly robustly built ones, can exhibit this for some time before the synchros bed in fully. The synchros are bronze and need to absorb oil into their working faces to operate properly. Ironically, the synchro may not work fully until the oil ages a bit.
Transmission lube is funny stuff, it must keep metal parts from sticking together under pressure but at the same time allow the synchros to stick together under certain pressure.
Some manual transmissions can take 10,000 or even 20,000 miles to fully bed in.
Suberman is offline   Reply With Quote
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 05:05 PM
This car really hates the cold weather Craig Issues | Warranty | Recalls / TSB 55 01-28-2013 06:42 PM
rattling in cold weather mezdup Issues | Warranty | Recalls / TSB 2 01-22-2013 09:32 AM
Cold-weather morning shifts NetMagi Scion FR-S / Toyota 86 GT86 General Forum 11 11-08-2012 11:05 AM
Cold / Wet weather brake issue? Ingen Scion FR-S / Toyota 86 GT86 General Forum 6 10-29-2012 11:42 AM
