Old 07-27-2013, 02:21 PM   #1
bear89103
Old Fart
bear89103's Avatar
Lost power in 1st gear and a bit of 2nd
Ok, just got an Injen SRA and Invidia N1 cat back installed.
First day driving its weird. I feel a big loss of power in 1st and a bit of power loss in 2nd. 3rd and 4th seem decently responsive. And 5th and 6th seem normal.
Is this just a break in situation?
Or is something seriously wrong?
bear89103 is offline   Reply With Quote
Old 07-27-2013, 03:05 PM   #2
FR-S Matt
Probably the Injen intake like a lot have seen with it. Check for leaks and tighten anything loose. Reset the ECU and let it learn. This intake seems to be okay once tuned but will run leaner than most.
Old 07-27-2013, 03:26 PM   #3
number1Tango
Drives: Silver FRS
try resetting the ecu and drive it around some more.
number1Tango is offline   Reply With Quote
Old 07-27-2013, 06:52 PM   #4
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
My car backfires alot more.
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
Old 07-28-2013, 12:53 AM   #5
d4wt
d4wt's Avatar
Drives: a couple + an frs
i have the exact same setup as you (just added unichip into the mix this morning). while i didn't notice any issues i would say definitely listen to what folks are saying when they tell you to disconnect the battery.
also... get a tune you won't regret it at all. while im a huge fan of actually flashing the ecu i went with unichip for warranty aspects. hell, i've only had the car about 3 weeks now lol.
d4wt is offline   Reply With Quote
Old 07-28-2013, 03:23 AM   #6
bear89103
Old Fart
bear89103's Avatar
I will do a battery pull tomorrow. Question tho. You said an ecu flash can invalidate warranty. Can't I just reflash back if I need to do warranty service?
Old 07-28-2013, 04:32 AM   #7
d4wt
d4wt's Avatar
yup, chances are they will not ever check. but for cases where they do then they would more than likely void your warranty even if it's flashed back to stock (they can tell). i had to go in this morning because they thought mine needed the COW ecm flash. apparently it did not but situations like this could bring on issues. especially if you want the DRL fix.
that being said, unichip is great for that very reason. it doesn't "flash" your ecu and leaves no evidence (footprint) that it was even there.
lost my step-dad 5/25/13. :( charged86 Off-Topic Lounge [WARNING: NO POLITICS] 49 06-02-2013 12:54 PM
WE LOST :( Johnp Scion FR-S / Toyota 86 GT86 General Forum 47 03-29-2013 04:10 PM
I lost over 25 lbs in less than an hour... GTB/ZR-1 Scion FR-S / Toyota 86 GT86 General Forum 44 12-10-2012 02:30 PM
im lost... lol _F-R-S_ Mid-Atlantic 2 10-07-2012 11:04 PM
Lost fans? 315FR-S Off-Topic Lounge [WARNING: NO POLITICS] 11 05-31-2012 04:13 PM
