Strange metallic vibration noise started
I'll post a video later tonight of it, it usually makes the noise in 3-4th gear @ ~4k rpms from the front passenger side. I poked around in the engine compartment and found a broken zip tie near the car battery, not sure what it holds but I didn't see anything loose. I'll put a picture of that at the bottom. This weekend I plan on lifting it up to check the heat shields/exhaust bolts. Does anyone else have some more suggestions on things to check or know what the broken zip tie holds?
Thanks http://imgur.com/a/EcdSH |
Did you buy the car new .... ??
humfrz |
| Strange noise/vibration under heavy engine load | Panecki17 | Issues | Warranty | Recalls / TSB | 65 | 05-04-2017 07:58 AM |
| Diff vibration/noise on decel | Im_SPEED | Engine, Exhaust, Transmission | 9 | 01-28-2017 09:18 PM |
| trd quick shifter ? vibration noise | Pcharliep04 | Issues | Warranty | Recalls / TSB | 5 | 08-01-2014 02:42 PM |
| Vibration/Noise near instrument cluster? | nktech | Scion FR-S / Toyota 86 GT86 General Forum | 11 | 03-28-2014 08:42 AM |
| Strange metallic rattle at around 3-4k rpm. | Brett | Issues | Warranty | Recalls / TSB | 17 | 11-08-2013 03:11 PM |
