Old 02-01-2023, 07:35 AM   #1
Mo.Ali
Drives: Toyota 86 2013
PCV connector leak
I have a minor leak from the PCV hose connector in 2013 86 ,
Do anyone has experience in that and do i have to change ?
Thanks
Mo.Ali is offline   Reply With Quote
Old 02-01-2023, 12:42 PM   #2
KillerBMotorsport
KillerBMotorsport's Avatar
Any time there is a vacuum leak, it should be repaired.
KillerBMotorsport is offline   Reply With Quote
The Following User Says Thank You to KillerBMotorsport For This Useful Post:
x808drifter (02-03-2023)
Old 02-05-2023, 12:27 AM   #3
humfrz
Thanks
Bubba says to tape it up with electrical tape.
x808drifter (02-05-2023)
Old 02-05-2023, 09:48 AM   #4
soundman98
ProCrastinationConsultant
soundman98's Avatar
should just be a new hose. easy enough to change
x808drifter (02-06-2023)
D78 connector repillows Electronics | Audio | NAV | Infotainment 1 01-29-2021 09:37 AM
Whats the name of this connector (3rd brake light connector) Chimera Cosmetic Modification (Interior/Exterior/Lighting) 4 01-10-2017 06:13 PM
ECM Pin Connector simpleisbest Software Tuning 19 01-18-2015 02:13 AM
What's this connector ? mashal Electronics | Audio | NAV | Infotainment 5 12-10-2013 01:13 AM
VSS Connector AlexTheGreek Engine, Exhaust, Transmission 15 02-02-2013 12:12 PM
