Drives: 2013 Scion Frs
D78 connector
I am on the hunt for a D78 connector pin out from a 2017+ wire harness. This connects to the clock spring and is found on the dash wire harness. Trying to convert my d51 connector on my 2013 FRS (which is the same type of connector but a 12 pin) to the D78 connector (which is 14 pin) so I can use the 2017 clock spring/steering wheel for steering wheel controls. Thanks!
#2 | |
Certs You Dont Care About
Drives: 2013 Galaxy Blue BRZ
From the Service Manual thread:
Specifically, the wiring diagram here: https://dgefsm40w4znf.cloudfront.net...G4467BE_wi.pdf The diagrams there show the connector numbers and the wire colors. I know the steering wheel controls are located on page 339. |
| Whats the name of this connector (3rd brake light connector) | Chimera | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 01-10-2017 06:13 PM |
| ECM Pin Connector | simpleisbest | Software Tuning | 19 | 01-18-2015 02:13 AM |
| What's this connector ? | mashal | Electronics | Audio | NAV | Infotainment | 5 | 12-10-2013 01:13 AM |
| Help, what connector is this? | Hayashi | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 02-26-2013 01:39 AM |
| VSS Connector | AlexTheGreek | Engine, Exhaust, Transmission | 15 | 02-02-2013 12:12 PM |
