Old 05-04-2022, 09:58 PM   #1
Longuy
Drives: 2013 FRS
wideband 02 sensor + ECU
does the ECU need access to a wideband O2 sensor for the car to function better... or is it used in conjunction, in tuning the car with stock o2 sensors. I've bought a wideband sensor and gauge... I know it can be logged but is it possible or beneficial to have it tied into the ECU?
I couldn't find any threads on this topic if you could link me would be great
Thank you for any response
Longuy is offline   Reply With Quote
Old 05-04-2022, 11:44 PM   #2
tomm.brz
Drives: brz 2017 hksv2
you can force the ecu to use it during open loop state of the ecu, the ecu will apply then a closed loop correction into the open loop using your wideband
thwre are failsafe but best usually, and how it ia used by many tuner, is that you use your wideband as a reference to rescale the stock lambda and make. it similar to the wideband using the stock one
The Following User Says Thank You to tomm.brz For This Useful Post:
Longuy (05-05-2022)
Old 05-06-2022, 11:19 AM   #3
Longuy
Drives: 2013 FRS
I see how it works now... I found it in the ProECU help file thanks again for your reply
The Following User Says Thank You to Longuy For This Useful Post:
tomm.brz (05-06-2022)
Wideband sensor tofurun Engine, Exhaust, Transmission 2 02-11-2017 10:42 AM
Wideband 02 sensor purpose? wbradley Forced Induction 11 08-17-2016 11:04 AM
is the front o2 sensor a wideband sensor? mad_sb Engine, Exhaust, Transmission 19 12-13-2015 02:20 PM
Where does wideband O2 sensor go? Turbowned Forced Induction 8 08-29-2014 02:16 PM
LC-1 wideband 02 sensor MattF Engine, Exhaust, Bolt-Ons 4 11-05-2013 09:52 PM
