Where does wideband O2 sensor go?
What's up guys,
I'm in the process of installing a Vortech S/C in my BRZ and have purchased an AEM wideband O2 sensor with failsafe. Do I have to weld in a separate bung for the wideband sensor, and if so, where should I put it (running a Tomei EL header and Perrin 2.5" overpipe)? Or, does it replace an existing sensor? Thanks in advance for the help!
Current: 2005 Porsche 911 Carrera S 6MT Previous: 2 BRZ's, 997 C2S, C5 RS6, C4 S6, B8 S4, GDB STi, S30 240Z, FC3S RX-7 TII, AW11/SW20 MR2, E30 318is/325i, etc. |
Mr. Cranky Pants
Drives: 2013 Argento FR-S
There's probably a way to put it in place of the rear O2 sensor and disable that second O2 in the ECU, someone in the software/tuning sub forum might be able to help you with that.
You could also add a bung for it, the overpipe would be a good place for it in my mind... |
If you're supercharged, you'll be running a custom tune so I'm assuming the secondary o2 sensor will be disabled. I'm pretty sure you can remove it and replace it with your sideband without getting a CEL. The secondary o2 sensor serves no purpose other than confirming if your catalytic converter is working.
OP has a Tomei EL header, he doesn't have a primary cat.
Drives: 2018 Golf R
Missed that part. It should be at least 18" from the exhaust ports. AEM widebands come with instructions with some more details regarding placement.
Parting out HERE
NASA SpecE30 Racer
You want it before any cat and as close to the merge point of the header as possible. If on a turbo car, you want it on the downpipe at least 18" from the turbo.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
Drives: 2013 Scion FR-S, 1993 Lexus SC300
I have a separate bung welded to my overpipe pointing up near the battery for the wideband. It is a very accessible location and I can remove/reinstall the sensor or a plug without removing anything else from the car.
Fantastic. Thanks for the help, guys!
| is the front o2 sensor a wideband sensor? | mad_sb | Engine, Exhaust, Transmission | 19 | 12-13-2015 02:20 PM |
| Greddy informeter, boost sensor, boost sensor harness, info touch sensor apaptor | Supra2k | Audio/Visual, Electronics, Infotainment, NAV | 1 | 02-26-2014 08:11 PM |
| LC-1 wideband 02 sensor | MattF | Engine, Exhaust, Bolt-Ons | 4 | 11-05-2013 09:52 PM |
| Innovate Wideband Air/Fuel Ratio LC-1 Wideband Kit **Special Price** | Titanmotorsports | Audio/Visual, Electronics, Infotainment, NAV | 2 | 09-14-2012 12:42 PM |
