Drives: 2014 BRZ Limited 6MT
Wideband sensor
What wideband sensor are you guys using? I am turbo and I just moved my front (gray plug) o2 sensor onto my downpipe. Is there a plug and play sensor or what sensor are you guys using to splice into the original plug. (My black plug air fuel sensor is behind it on the test pipe, not trying to change it)
Drives: Late 2014 Subaru BRZ
I have 3 o2 sensors on my car. On my down pipe i have my primary first then my AEM Failsafe windband and then my original cat o2 that just kinda chills there. The ECUtek rich and lean code is disabled but its still required to be there with my tune. My gauge is mounted with a cravenspeed pod on top of my steering column but in front of my gauge, blocking the worthless analog Speedo. Power for the AEM failsafe is supplied by the cigarette lighter port behind glove box.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe |
Drives: UK GT86
You cannot replace the front O2 sensor, this must be OEM or equivalent. Only the rear one can be replaced/removed.
.: Stealth 86 :.
| Wideband 02 sensor purpose? | wbradley | Forced Induction | 11 | 08-17-2016 11:04 AM |
| is the front o2 sensor a wideband sensor? | mad_sb | Engine, Exhaust, Transmission | 19 | 12-13-2015 02:20 PM |
| WTB: wideband sensor/gauge | SterlingBrz | Want-To-Buy Requests | 0 | 09-13-2014 11:54 AM |
| Where does wideband O2 sensor go? | Turbowned | Forced Induction | 8 | 08-29-2014 02:16 PM |
| LC-1 wideband 02 sensor | MattF | Engine, Exhaust, Bolt-Ons | 4 | 11-05-2013 09:52 PM |
