Old 08-15-2016, 09:22 PM   #1
wbradley
Sarcastic SOB
wbradley's Avatar
Wideband 02 sensor purpose?
Hi, I have a question that people might know the answer or have a knowledgeable opinion -
When my car was dyno tuned last year the tuner commented I ought to get a bung welded in the over pipe and install a wideband sensor. He also told me the tune was speed density based and the MAP meters the air so temperature and things can affect the engine control.
So, is the wideband sensor added to the Ecutek parameters for the ECU or is this just for me to monitor or set failsafe for lean/rich condition?
Old 08-15-2016, 09:50 PM   #2
Amputechture
Drives: 2014 BRZ
They detect a wider range of oxygen to fuel. From what I understand, the factory O2 sensors do not read accurately once the exhaust gets to a certain point on the rich side because the sensors were never meant to see it in that window. Although the factory O2 sensors can be rescaled to read within the same range and a lot of tuners claim that widebands are more of a hassle than anything because of this.
Amputechture is offline   Reply With Quote
Old 08-15-2016, 09:55 PM   #3
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
I use aem failsafe that monitors my a/f and boost/vacuum and its set to kill my ignition after being 10.9/1 for more than afew secs and if boost hits more than 10psi for a few secs. ECU doesn't have a clue its there and its not part of my tune.
The gauge is awesome and can be a life saver, i just had to use it when my fuel pump just started to take a shit.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 08-16-2016, 08:24 AM   #4
Toyota John
Calle Atun
Drives: 13 FRS, 93 Mr2, 85 ae86
You have two options
1) install a wideband to view your AFR
2) install a wideband to an unused input and with custom maps in ECUTEK can log it for easier tuning.
Toyota John is offline   Reply With Quote
Old 08-16-2016, 08:41 AM   #5
wbradley
Sarcastic SOB
wbradley's Avatar
So then the wideband would have made the vehicle easier to tune had there been one installed prior to tuning?
Really what concerns me is whether it is necessary to optimize the engine control. So, I gather it is not tied to ECU parameters then?
Sorry if I seem kind of dense on the subject. If it doesn't affect performance I am not too concerned. Overboost not a concern, my pulley limits that. Never heard engine knock ever.
Old 08-16-2016, 10:04 AM   #6
Kodename47
Kodename47's Avatar
Drives: UK GT86
3) Both of the above
.: Stealth 86 :.
Kodename 47 DJ:
Old 08-16-2016, 10:23 AM   #7
steve99
theoeticly you could rescale the stock 02 sensor to read down to 10 afr
then create a custom map in ecutek of afr vs boost and trigger a failsafe if boost vs afr is outside desired limits all within ecutek software, no hardware required. ?
Old 08-16-2016, 11:57 AM   #8
wbradley
Sarcastic SOB
wbradley's Avatar
steve99 , I consider you authoritative on the subject.
I am wondering if the quality of my custom dyno tune is what it should/could have been or since I didn't have a wide band does that mean I end up with a half-assed tune? I am wondering if he would have used AFR parameters read from the wide band otherwise and if that in fact would result in a better tune. NO CL's, etc.
Right now with speed density tables applied I understand that means the air is metered by the MAP rather than the MAF, and adjusted for intake temperature? If that is correct then temp will correct for air density, but a wide band actually has real time feedback from the resultant exhaust.
I am just wondering if I am settling for a half-ass tuning job the way I am set up now.
I just want someone to say yes you really do need this or no it is not necessary except for an over boost or lean/rich alarm.
Old 08-16-2016, 12:03 PM   #9
Kodename47
Kodename47's Avatar
Drives: UK GT86
Most dynos have a WBO2 that would have been put in the tailpipe. I would expect that they will have tuned off this, not logged AFRs. A WBO2 in the exhaust is not necessary at all for an SC car that is tuned correctly. Unless you're going to spend time tuning from a WBO2 on the road then you'll gain little by installing one.
.: Stealth 86 :.
Kodename 47 DJ:
The Following 2 Users Say Thank You to Kodename47 For This Useful Post:
steve99 (08-16-2016), wbradley (08-16-2016)
Old 08-16-2016, 03:50 PM   #10
nickw14
Drives: Built FA20
Delicious apparently scales the stock O2 sensors to read more accurately/wider range. Zach told me I didn't need a wideband. ... after I already bought one.
nickw14 is offline   Reply With Quote
Old 08-16-2016, 05:48 PM   #11
steve86gt
Drives: 2014 Toyota gt86 avo stg 2 e85
Im running an AEM failsafe afr , best investment !!
steve86gt is offline   Reply With Quote
Old 08-17-2016, 11:04 AM   #12
Toyota John
Calle Atun
ECUTEK has a suggested O2 scalling for the lower AFR numbers. You need to change the resolution as well as AFR numbers lower then 14.7 don't have much use to the ECU and there are less points down there. I have been using them but the scale is not accurate below 12. I have been rescaling the points below 14.7 to be more accurate. I am willing to bet that this will need to be done on each car as the sensors might not be the same on every car.
is the front o2 sensor a wideband sensor? mad_sb Engine, Exhaust, Transmission 19 12-13-2015 02:20 PM
Wideband O2 Sensor questions. Frishkorn Software Tuning 2 08-29-2015 05:27 PM
WTB: wideband sensor/gauge SterlingBrz Want-To-Buy Requests 0 09-13-2014 11:54 AM
Where does wideband O2 sensor go? Turbowned Forced Induction 8 08-29-2014 02:16 PM
LC-1 wideband 02 sensor MattF Engine, Exhaust, Bolt-Ons 4 11-05-2013 09:52 PM
