Drives: 2013 White Subaru BRZ
Disconnecting A/C Condenser
Hey guys.
Currently in the process of repair front end collision. I need to remove my a/c condenser but how do I go about disconnecting the two a/c lines. I know the top one is pressurized and needs to be done a certain way but what about the bottom one. Can I just unbolt it no issues? (Image attached… I think) |
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Both are pressurized. Have the system evacuated of it's refrigerant before opening. Find a mobile AC tech to do it, he'll also need to come back to properly vacuum and refill the system once your repairs are done.
[edit] It's VERY BAD to dump R134a into the atmosphere, it's 1400 times more potent than CO2 as a greenhouse gas, so dumping a pound of the stuff (like a typical small-car AC can hold) is, as you'd imagine, like dumping out 1400 pounds of CO2. |
| BRZ Bluetooth phone keeps disconnecting | Alltezza | Electronics | Audio | NAV | Infotainment | 20 | 01-26-2023 12:00 PM |
| Properly disconnecting battery? | HachiRo | Cosmetic Modification (Interior/Exterior/Lighting) | 6 | 03-16-2016 07:29 PM |
| Android keeps disconnecting | kmac_brz | Electronics | Audio | NAV | Infotainment | 8 | 08-12-2015 04:35 PM |
| Bluetooth Disconnecting | pseudo | Issues | Warranty | Recalls / TSB | 5 | 11-03-2014 02:34 PM |
| Disconnecting the battery? | Reflex | Electronics | Audio | NAV | Infotainment | 4 | 04-08-2014 01:55 PM |
