Old 04-08-2014, 04:11 AM   #1
Reflex
Drives: Whiteout FR-S
Disconnecting the battery?
Never installed a car stereo before so I'm going to try to do it. I've read that I should disconnect the battery from some sources but a few others said don't. What do you guys suggest?
Reflex is offline   Reply With Quote
Old 04-08-2014, 06:42 AM   #2
speedrye
Drives: White
Are you just replacing a head unit, or are you adding an amp and other stuff as well?
speedrye is offline   Reply With Quote
Old 04-08-2014, 11:25 AM   #3
tiz22
tiz22's Avatar
Drives: 2013 Scion FR-S (Raven) MT
Rule of thumb is to disconnect the battery whenever you're working with electronics/wiring in the car...It's really easy to do so I don't know why you'd risk it
My Car Journal: Raven FR-S w/ TRD Flavour
Click for my AVIC Z150BH Head Unit DIY Install
tiz22 is offline   Reply With Quote
Old 04-08-2014, 12:32 PM   #4
mashal
DADA
mashal's Avatar
Drives: 2013
If you are replacing a HU , then it shouldnt really matter as long as the car is off. I still highly suggest you disconnect the battery
mashal is offline   Reply With Quote
Old 04-08-2014, 01:55 PM   #5
Boxer486
Drives: small
If you aren't comfortable disconnecting the battery and dealing with the proper process to do so, you shouldn't be working on a car.
http://www.pepboys.com/parts/batteries/diy_replacing/
Just make sure you cover your fender to prevent paint damage from the battery or you rubbing up on it. Take off your watch and don't let anything metal that could touch your skin come into contact with both terminals at the same time.
Boxer486 is offline   Reply With Quote
The Following 2 Users Say Thank You to Boxer486 For This Useful Post:
eurominican (08-12-2014), Prog (04-08-2014)
Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package KCMachine Brakes, Suspension, Chassis 111 10-08-2014 08:26 AM
Possible to remove headers without disconnecting frontpipe? jonboy99 Engine, Exhaust, Transmission 3 10-21-2013 12:16 AM
Tips and Tricks: Disconnecting the Battery Necessary Post Intake Install? ScionFR-S Engine, Exhaust, Transmission 8 12-17-2012 05:39 AM
TR-B1500 battery and billet battery tray install. mines13 DIY (Do-It-Yourself) Guides 8 12-07-2012 03:59 PM
Disconnecting battery for installations i_4got Electronics | Audio | NAV | Infotainment 2 11-21-2012 01:04 AM
