Old 03-16-2016, 01:27 AM   #1
HachiRo
Drives: 2013 White-Out FRS
Properly disconnecting battery?
Installing a harness bar tomorrow that requires removal of the B-pillar. I don't believe I'm removing the part where the airbag actually is, but I rather play it safe.
What's the proper way to disconnect the battery? Remove the negative terminal then let it sit for 10 minutes? Or should I step on the brake a couple of times to remove excess charge as I've read?
Also, if disconnected long enough, will it reset my ECU and in doing so, require me to drive under RPMs or a certain way for awhile?
I live my life one quarter-pounder at a time.
HachiRo is offline   Reply With Quote
Old 03-16-2016, 08:10 AM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
1) remove negative terminal
2) remove positive terminal
3) remove tie-down
4) lift battery out
5) carry battery 3.2kms away from car
6) proceed to work on car
Jokes aside just disconnect the negative and put a rubber glove over it just incase it decides it wants to touch something lol. When it come to airbags and shit they say let it sit 10 minutes blah blah blah. I took my airbag out once and totally forgot to disconnect the battery and I am still alive. You are over thinking this haha. Your ECU will be fine you can drive like normal.
Old 03-16-2016, 01:19 PM   #3
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
god damn it. It supposed to be 2.3km away.
Old 03-16-2016, 01:21 PM   #4
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
I always go the extra 0.9km's away just to be on the safe side
Old 03-16-2016, 06:49 PM   #5
HachiRo
Thanks all!
Pretty sure that was long enough to reset my ECU. Now it shakes violently when stopping and throttle has major lag. This is only cause it's relearning or whatever right? It'll go away in a couple miles/days?
Old 03-16-2016, 07:19 PM   #6
xFury
xFury's Avatar
Drives: '16 Scion FR-S - Oceanic
Originally Posted by HachiRo View Post
Thanks all!
That is correct. It has to relearn the throttle and everything, drive it around for a while or few days and it should go away. Now to make it quicker, I'm not sure, I hear mix stuff, some say WOT some times and some say don't WOT. But I say just drive it like you normally do, nothing special. Take it with a grain of salt.
xFury is offline   Reply With Quote
Old 03-16-2016, 07:29 PM   #7
HachiRo
Awesome! Thanks!
Properly hooking up dead battery. lupindub Other Vehicles & General Automotive Discussions 13 01-19-2016 01:00 PM
Will the dealership "ECU Flash" be reset to factory after disconnecting battery? spatcha88 Engine, Exhaust, Transmission 5 04-02-2015 02:35 AM
Disconnecting the battery? Reflex Electronics | Audio | NAV | Infotainment 4 04-08-2014 01:55 PM
Tips and Tricks: Disconnecting the Battery Necessary Post Intake Install? ScionFR-S Engine, Exhaust, Transmission 8 12-17-2012 05:39 AM
Disconnecting battery for installations i_4got Electronics | Audio | NAV | Infotainment 2 11-21-2012 01:04 AM
