Old 07-27-2015, 09:20 PM   #1
kmac_brz
Drives: 14 WRB BRZ
Android keeps disconnecting
I have a Samsung Galaxy S6 and for some reason the Bluetooth doesn't always pick it up when I get in the car, even though I have auto connect on. Also sometones qhen listening to music it just disconnects on it's own.
The phone is usually in my lap by the way.
Any advice would be great
kmac_brz is offline   Reply With Quote
Old 07-27-2015, 09:27 PM   #2
ringo16
Drives: 15 Asphalt FRS
Try deleting the Bluetooth pairing from your car and pair it again.
ringo16 is offline   Reply With Quote
Old 07-27-2015, 09:54 PM   #3
aegisdrgn
aegisdrgn's Avatar
Drives: Scion FR-S 10 Series #2263
Does the phone get hot? My phone (HTC One M7) used to disconnect when it got hot, but now that I mount it right in front of the AC vents (with AC on), the bluetooth connection is rock solid.
aegisdrgn is offline   Reply With Quote
Old 07-28-2015, 09:54 AM   #4
kmac_brz
Drives: 14 WRB BRZ
I've never had a problem with it getting hot. Never thought of that, I'll try disconnect and reconnect first.
Old 07-30-2015, 03:29 PM   #5
LXXXV1
LXXXV1's Avatar
Drives: 2014 FR-S Monogram, Whiteout 6MT
Having the same issue...did the recovery mode to wipe the bluetooth cache, deleted car from phone, phone from car, force stopped it in apps and cleared cache, tried everything short of completely resetting the phone which I'd like to avoid. Still disconnecting. Pretty annoying when I'm trying to make a call.
2007 Honda CBR600RR-Pearl White/Silver - Totaled
2014 Scion FR-S Monogram-Whiteout - #LXXXV1 (build)
φφκα
LXXXV1 is offline   Reply With Quote
Old 07-30-2015, 03:42 PM   #6
stugray
Drives: 2013 GBS BRZ Limited
My older droid phone used to do this. I tried every fix suggested and could never make it work consistently. Got a newer model droid phone and never had the problem once.
Old 07-30-2015, 06:47 PM   #7
DJCarbine
Thupercharged
DJCarbine's Avatar
My old Note 2 did this, my "fix" as I used a lot of bluetooth streaming was to push the button to select radio, then back to streaming mode. It would usually fix it for me, but it was VERY annoying. Since then I've had 2 new android phones and they work perfectly fine.
If the radio doesn't pick up the phone bluetooth at all on startup, then I could not find a way to fix that. Happened to me like once every 10 trips.
Side note, in my other car the bluetooth constantly disconnected until I got a different headunit. Certain headunit/phone combinations seem to have problems.
2013 FRS
Vortech V3 11psi
Old 08-10-2015, 01:44 AM   #8
2isballer
Drives: 2014 Scion FR-S
I'm having the exact same problem! Just started happening about a month ago. I have an HTC One M7.
Reset the headunit and still having problems. Any fixes?
2isballer is offline   Reply With Quote
Old 08-12-2015, 04:35 PM   #9
Matey
Drives: Pearl White BRZ
Mine only disconnects from the BT when I change the volume on my head unit. Annoying asf
Matey is offline   Reply With Quote
BRZ Bluetooth phone keeps disconnecting Alltezza Electronics | Audio | NAV | Infotainment 20 01-26-2023 12:00 PM
Bluetooth Disconnecting pseudo Issues | Warranty | Recalls / TSB 5 11-03-2014 02:34 PM
Disconnecting the battery? Reflex Electronics | Audio | NAV | Infotainment 4 04-08-2014 01:55 PM
Possible to remove headers without disconnecting frontpipe? jonboy99 Engine, Exhaust, Transmission 3 10-21-2013 12:16 AM
Disconnecting battery for installations i_4got Electronics | Audio | NAV | Infotainment 2 11-21-2012 01:04 AM
