Old 10-18-2021, 06:51 AM   #1
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
Ice Fabrication/off the line coil pack connectors - Upgrade to 2015+
Anyone give this product a shot yet? I am curious about quality. I found a set of 2015+ coil packs a while ago for a steal so this could be a good low budget option to solve the 2013-2014 coil pack issues. I ordered a set and will report back on the install and results.
https://www.icefabrication.com/produ...grade-to-2015/
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
The Following User Says Thank You to Takumi788 For This Useful Post:
DarkSunrise (10-18-2021)
Old 10-18-2021, 09:23 AM   #2
Joon525
Joon525's Avatar
Drives: 2016 BRZ
Just putting this out here for an additional source of materials for anyone in the same situation as you.
https://www.iwireservices.com/produc...or-brz-and-frs
Joon525 is offline   Reply With Quote
The Following 2 Users Say Thank You to Joon525 For This Useful Post:
Grady (01-05-2022), makinen (10-19-2021)
Old 10-18-2021, 09:59 AM   #3
Takumi788
JHerbert Racing
Takumi788's Avatar
Now that I am seeing this, I wonder if I could just de-pin the current 2013 connectors and put the OEM terminated crimps into the 2015+ connector......I might have just spent too much money on pre-terminated pigtails.
I reached out to both companies asking if the terminal pins are the same on the 2013-14 and 2015+. I will report back when I get a reply.
Old 10-18-2021, 12:09 PM   #4
Takumi788
JHerbert Racing
Takumi788's Avatar
Ice Fabrication replied stating they tried looked into the pins and they are in fact different. So new pins are required.
Old 10-18-2021, 12:38 PM   #5
Joon525
Joon525's Avatar
Drives: 2016 BRZ
There's also this
https://www.ftspeed.com/part/coil-ad...t#.YW2ir1XMIuU
The Following User Says Thank You to Joon525 For This Useful Post:
Old 10-18-2021, 12:52 PM   #6
Takumi788
JHerbert Racing
Takumi788's Avatar
UGH. That would be much easier.
Old 10-18-2021, 01:18 PM   #7
Joon525
Joon525's Avatar
Drives: 2016 BRZ
I JUST remembered that. Maybe it's not too late to cancel your order though?
Old 10-18-2021, 04:22 PM   #8
Takumi788
JHerbert Racing
Takumi788's Avatar
Thanks. Ice Fab was really understanding. I will snag those from FT86 Speedfactory instead
Joon525 (10-18-2021)
Old 10-18-2021, 06:13 PM   #9
radroach
Drives: car
@Takumi788 what are the coil pack issues on '13-14?
The Following User Says Thank You to radroach For This Useful Post:
kevaughan (01-07-2022)
Old 10-19-2021, 06:45 AM   #10
Takumi788
JHerbert Racing
Takumi788's Avatar
The 2013-2014 coil packs fail when in high demand environments like the racetrack or boosted applications. Subaru/Toyota upgraded them somewhere mid-2014 to a more heat resilient coil pack. Unfortunatly when they did this they changed the connector. So they are not a direct replacement. Thus this thread.
Old 10-19-2021, 08:50 AM   #11
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Just curious. Has anybody done a side by side comparison of the early vs late coil packs? Other than the plug, what is the difference? Old ones fail due to age. Do the new ones actually last longer?
Old 10-20-2021, 05:33 PM   #12
DarkSunrise
DarkSunrise's Avatar
Using e85 also seems to make the issue worse, especially in track conditions.
I’m also curious to know how much of a difference the 2017 coilpacks make.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
blsfrs (10-20-2021)
Old 10-21-2021, 06:54 AM   #13
Takumi788
JHerbert Racing
Takumi788's Avatar
I will do a side by side comparison when my parts come in. I assume they appear identical. I cant find the information but I remember in 2015 when subaru had their first engine component update it was stated that they were an enhanced design to deal with the heat issues they saw on the 2013-2014. I am sure age takes a toll but heat is also a contributing factor to coil failure. My car is a dedicated track car and in the 8 years (almost 50k miles) I have owned it, doing 10-35 track days a year, I have gone through 4 coils.
blsfrs (10-21-2021)
Old 10-21-2021, 09:55 AM   #14
DarkSunrise
Nice, looking forward to the comparison!
Really similar numbers on my 2013 as well. Owned for 9y/48k miles, 40+ track days, lot of canyon drives, and... 6 coils
Agree on heat being a major contributor.
2022 BRZ Build
2013 FR-S Build
blsfrs (10-21-2021)
Upgrade 2013 to newest coil pack design and connectors jflogerzi Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 11-07-2020 03:13 PM
Coil Pack upgrade 2015 BRZ Mad-BRZ BRZ First-Gen (2012+) — General Topics 2 04-14-2019 11:53 AM
Coil pack options ROADRACER Engine, Exhaust, Transmission 14 12-24-2018 02:33 AM
Coil ignition pack D86Ellis Issues | Warranty | Recalls / TSB 7 09-20-2016 02:01 AM
Coil pack part numbers? feldy Engine, Exhaust, Transmission 6 03-11-2014 11:31 AM
