Upgrade 2013 to newest coil pack design and connectors
I know the early cars had issues. I am getting ready to remove my super charger to prepare for smog and might as well take care of a few things on the car above the manifold will be off
OEM spark plugs New front O2 sensor Newest oem coil packs and connectors Any have part numbers to do this. Car is 2013 and has almost 73k on the odo. Might as well do these all in one shot. Sent from my GM1915 using Tapatalk
2013 Series 10 FRS #553
You could do the Delicious coil packs. Better design same old connector.
I thought part of the problem was the connection more so than the coil itself
#4 | |
Drives: Scion FRS 10 series
I just did the conversion myself here are the part numbers, also the coolant temp sensor and oil temp sensor have different style plugs, you will need to swap connectors or get 2016+ sensors
HARNESS-ENGINE. 24020AG080 COIL ASSEMBLY-IGNITION. 22433AA730 Quote:
Drives: 18 Brz (Sold) / 22 BRZ / 13 BRZ
How to adapt the 16+ coil pack on the 13?
| ISO coil pack connector pigtail | thE_iyE | Want-To-Buy Requests | 1 | 09-22-2019 01:52 AM |
| Coil Pack upgrade 2015 BRZ | Mad-BRZ | BRZ First-Gen (2012+) — General Topics | 2 | 04-14-2019 11:53 AM |
| Coil pack options | ROADRACER | Engine, Exhaust, Transmission | 14 | 12-24-2018 02:33 AM |
| Coil ignition pack | D86Ellis | Issues | Warranty | Recalls / TSB | 7 | 09-20-2016 02:01 AM |
| Coil pack part numbers? | feldy | Engine, Exhaust, Transmission | 6 | 03-11-2014 11:31 AM |
