Old 09-14-2016, 04:51 PM   #1
D86Ellis
Drives: '13 Scion FRS
Exclamation Coil ignition pack
Okay so I found out today that it looks like I'm having to replace the coil ignition pack due to my ecu showing code p0354. From what I have read you only have to replace it on cylinder 1 (if you catch it early enough. But I can't figure out what cylinder is cylinder 1. I know it is on the passenger side. But is it front or back. Any advice would be appreciated
D86Ellis is offline   Reply With Quote
Old 09-14-2016, 05:02 PM   #2
Thorpedo
The SquadWhisperer
Drives: '13 Ultramarine FR-S (STX)
Cylinder 1 is the one that is most forward on the entire engine.
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion
2017 Bluenose Autosport Club Overall Rallycross Champion
Powered by Great North Performance, Jani-King Canada, and OK Tire.
Thorpedo is offline   Reply With Quote
Old 09-14-2016, 05:02 PM   #3
Tectoniic
#FiftyShadesOfBlue
Tectoniic's Avatar
Drives: 2015 FR-S
From a birds eye view
Front of car
2 1
4 3
Rear of car
Quoting this back from a 2012 thread for what it's worth:
firing order 1-3-2-4,
Should be front Passenger #1, front drivers #2, rear passenger #3, rear drivers #4
86mm bore, and stroke, I'm not sure of the Rod length
http://www.ft86club.com/forums/showthread.php?p=114179
Engine/Exhaust: OFT w/ E85 Tune | FT86SF Catted UEL | Invidia Q300 Catback
Wheels/Tires/Suspension: Avid.1 AV-20 18x8.5 +33 w/ 245/35/18 PSS | RCE Yellow Springs | Velox LCAs
Cosmetic: Valenti FT86SF Special Edition Tails | Diode Dynamics Full HID/LEDs | BRZ Fender Garnishes
Tectoniic is offline   Reply With Quote
Old 09-14-2016, 07:47 PM   #4
D86Ellis
Thumbs up
Sweet that helps a lot. I appreciate it
Old 09-14-2016, 08:50 PM   #5
humfrz
Are you sure #1 coil is the bad actor ....... and not #4 .. ??
http://www.autocodes.com/p0354_scion.html
Maybe this should be verified .. ??
humfrz
Old 09-15-2016, 12:38 PM   #6
strat61caster
strat61caster's Avatar
^ Yes 0351 is #1, 0352 is #2, 0353 is #3, 0354 is #4, at least according to the code reader I have which reads out some details.
ineedyourdiddly
Old 09-15-2016, 12:50 PM   #7
Icecreamtruk
Drives: Track preped NA FRS
Like many have mentioned, p0354 is coil pack D (or #4). The code is not to replace all of them, just the one that is having problems. You can reach that coil pack without moving or taking anything out of the engine, it should be a 15-30minutes max to change it (number 2 is the only real bitch, 1 and 3 are easy to change too).
Old 09-20-2016, 02:01 AM   #8
humfrz
So, @D86Ellis .... did you get your car fixed .. ??
humfrz
coil pack, coil pack ignition, cylinders, ecu, p0354
Ignition Coil A CEL Whats that smell? Issues | Warranty | Recalls / TSB 12 10-10-2016 01:09 PM
4 OEM spark plugs and 1 OEM ignition coil Kronos Engine, Exhaust, Bolt-Ons 12 07-29-2016 10:08 AM
Is $460 too much for 1 oem coil pack & spark plugs from mechanic? spatcha88 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 24 03-21-2015 12:08 PM
ignition coil pack #2 and #3, dealer won't cover vestal52 Issues | Warranty | Recalls / TSB 28 10-16-2014 11:24 PM
Coil pack part numbers? feldy Engine, Exhaust, Transmission 6 03-11-2014 11:31 AM
