Drives: 2014 FR-S
Driveshaft will not lineup with rear diff during clutch install
Hello! I am having difficulty during the last steps of replacing the clutch and flywheel on my 2014 FRS. I have been following the DIY guide here along with other videos and tutorials.
The car was in neutral when I removed the transmission but I fear it went into gear during some part of the install. I have seen videos where you can pull or push on the shift linkage to get it in and out of gear respectively. The drive shaft will not spin in either case to line up the rear portion to to the differential. Should I install the shift lever and attempt to put it in neutral with the engine turned off? Do I need to fill the trans with gear oil to do this? Or did I mess up royally somewhere and need to start over? Any help is appreciated. Thanks! |
#2 | |
Sent from my ONEPLUS A5010 using Tapatalk |
Drives: 2013 frs base
Or release the E brake and rotate a rear wheel.
Drives: 2014 FR-S
Thank you!
Señor Member
This seems the obvious solution.
1974 TA22 Celica
2013 86 GT |
| Which is better? Reaplcing rear diff bushings? or installing rear diff brace? | Frs30 | Engine, Exhaust, Transmission | 22 | 04-13-2020 10:23 AM |
| FS: CF Driveshaft - ACT HD Clutch - Streetlite Flywheel - DSS driveshaft and MORE | prandelia | Transmission and Driveline | 6 | 04-10-2020 06:43 PM |
| Is it ok to install the Cusco diff collars without the rear inserts? | Ultramaroon | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 09-27-2019 11:25 PM |
| Diff Mount Inserts install - Diff won't lower??? | ChRZ | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 07-17-2017 12:07 AM |
| AVO Rear Diff Anti-tramp Bushing Install Pix | Infamous Performance | DIY (Do-It-Yourself) Guides | 2 | 09-29-2014 04:48 PM |
