Old 09-29-2014, 03:46 PM   #1
Infamous Performance
Infamous Performance's Avatar
Drives: 02 WRX, 05 LGT, 08 LGT, 08 SpecB
AVO Rear Diff Anti-tramp Bushing Install Pix
The AVO Rear Differential Anti-Tramp Insert Bushing will firm up the rear differential bushing in your Subaru. This reduces excess differential movement under power, eliminating wheel hop when taking off from a stop.
This also keeps power from being lost due to excess differential movement under power.
As this is an insert, it's extremely easy to install and doesn't require you to press out the old bushings to use.
Specifications:
Polyurethane bushing
Applied Models:
2013+ Subaru BRZ
2013+ Scion FR-S
2013+ Toyota GT86
Infamous Performance is offline   Reply With Quote
Old 09-29-2014, 04:28 PM   #2
Dipstik-sportech
Dipstik-sportech's Avatar
I wouldn't say these bushing eliminate wheel hop, reduces maybe
Old 09-29-2014, 04:48 PM   #3
Verbiage is straight from AVO's website. Not my words.
They do reduce wheel hop. At stock power levels they eliminate it. Notice the test car has a stock rear sway bar and stock exhaust (stock tires too)? It is Supercharged making 265-275whp on my Mustang dyno. We have noticed no wheel hop since the install and there is definitely less differential movement.
Perrin Rear Shifter Bushing Install F1point4 DIY (Do-It-Yourself) Guides 55 10-21-2021 02:39 PM
Whiteline rear subframe bushing install... fl_speed001 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 35 07-11-2020 12:29 AM
kartboy short shifter and rear shifter bushing install and review. FR-S UMB FR-S DIY (Do-It-Yourself) Guides 21 10-18-2014 01:41 AM
Sheared my Whiteline anti-lift kit bushing! Tye300 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 01-04-2014 06:14 PM
diff bushing questions mike the snake Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 08-25-2013 05:28 PM
