Old 07-13-2019, 04:09 PM   #1
Ultramaroon
not playing cards
Ultramaroon's Avatar
Is it ok to install the Cusco diff collars without the rear inserts?
They're sold separately but I think that, because the front collars create a hard mount point, it's asking too much of that cantilevered load to support all of the torsion. I still see significant vertical deflection at the left rear isolator.
Anyone running like this? How long?
Old 07-15-2019, 04:37 PM   #2
Ultramaroon
not playing cards
Nobody? Am I that special?
Old 07-15-2019, 04:42 PM   #3
StraightOuttaCanadaEh
Wes
I ran it that way for 5-6 months, no issues. I had the Whiteline inserts though, don't know if that makes a difference
Instagram: @gt86ws
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post:
Ultramaroon (07-15-2019)
Old 07-15-2019, 09:11 PM   #4
Ultramaroon
not playing cards
IIRC the Whiteline inserts are polyurethane, yes?
The steel Cusco collars take up all the available slack. There's a hard plastic layer but it doesn't actually have any give. They're literally hard mount points now. Feels great but I'm a little worried about the cyclical load on those screws.
I'll watch it carefully the next few weeks.
Old 07-15-2019, 09:49 PM   #5
Wes
Eeek how’s the NVH? Cause I have the polyurethane diff inserts but I’m quite alright with the extra noise and clatter so if I can reduce the slop even more, I’m willing to go even stiffer
Instagram: @gt86ws
Old 07-16-2019, 12:43 AM   #6
Ultramaroon
not playing cards
There's a bright resonance right around 120 Km/hr. I'm ok with it today but I need to do some highway cruising before I commit. On the flip side, ten minutes on the Rhino ramps and it's back to stock.
StraightOuttaCanadaEh (07-16-2019)
Old 09-27-2019, 11:25 PM   #7
Ultramaroon
not playing cards
I removed them yesterday. Without equal support at the rear, the reaction torque is transmitted right through the mounting screws. The diff was yanking on the screws hard enough to make them creak.
The remaining backlash hammered with with an intensity that felt unhealthy.
Diff Mount Inserts install - Diff won't lower??? ChRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-17-2017 12:07 AM
FS: Whiteline rear diff inserts rever5e Brakes, Suspension, Chassis 6 03-16-2015 08:23 PM
Cusco Engine Mounts and Cusco Rear Diff Brace - Stiffen up your BRZ/FR-S!!! RallySport Direct Transmission and Driveline 10 03-12-2013 02:11 PM
Cusco Rear Diff Covers!!! Cusco LSD Units! vividracing Transmission and Driveline 0 06-18-2012 03:24 PM
Cusco Rear Diff. Jewelry Blaaaack-BRZ Engine, Exhaust, Transmission 24 05-12-2012 03:28 PM
