Old 08-30-2021, 07:04 PM   #1
ShittyMechanic
Drives: 2014 FR-S
Driveshaft will not lineup with rear diff during clutch install
Hello! I am having difficulty during the last steps of replacing the clutch and flywheel on my 2014 FRS. I have been following the DIY guide here along with other videos and tutorials.
The car was in neutral when I removed the transmission but I fear it went into gear during some part of the install. I have seen videos where you can pull or push on the shift linkage to get it in and out of gear respectively. The drive shaft will not spin in either case to line up the rear portion to to the differential.
Should I install the shift lever and attempt to put it in neutral with the engine turned off? Do I need to fill the trans with gear oil to do this? Or did I mess up royally somewhere and need to start over?
Any help is appreciated. Thanks!
ShittyMechanic is offline   Reply With Quote
Old 08-30-2021, 07:09 PM   #2
Ashikabi
Ashikabi's Avatar
Just go ahead with the shifter install and put the drive shaft in last. You don't need fluid in it. You're not gonna hurt anything, nothing to worry about
Sent from my ONEPLUS A5010 using Tapatalk
Old 09-02-2021, 10:20 AM   #3
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Or release the E brake and rotate a rear wheel.
The Following 2 Users Say Thank You to blsfrs For This Useful Post:
Turdinator (09-06-2021), Ultramaroon (09-08-2021)
Old 09-03-2021, 12:41 PM   #4
ShittyMechanic
Drives: 2014 FR-S
Thank you!
Old 09-06-2021, 10:40 PM   #5
Turdinator
Señor Member
Turdinator's Avatar
This seems the obvious solution.
1974 TA22 Celica
2013 86 GT
Which is better? Reaplcing rear diff bushings? or installing rear diff brace? Frs30 Engine, Exhaust, Transmission 22 04-13-2020 11:23 AM
FS: CF Driveshaft - ACT HD Clutch - Streetlite Flywheel - DSS driveshaft and MORE prandelia Transmission and Driveline 6 04-10-2020 07:43 PM
Is it ok to install the Cusco diff collars without the rear inserts? Ultramaroon Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 09-28-2019 12:25 AM
Diff Mount Inserts install - Diff won't lower??? ChRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-17-2017 01:07 AM
AVO Rear Diff Anti-tramp Bushing Install Pix Infamous Performance DIY (Do-It-Yourself) Guides 2 09-29-2014 05:48 PM
