Old 08-22-2021, 01:16 PM   #1
Rabrooks
Rabrooks's Avatar
Drives: 2020 Subaru BRZ
New cam grind?
I have a spare set of cams. Does anyone know if a cam grinder can create a higher lift cam from my stock set? I want to port the heads but I want to be able to take advantage of the better flow with either a higher lift or a longer duration.
Can someone share where I can fi d out the cam specs static and also at full vvt advance.
Thanks
Rabrooks is offline   Reply With Quote
Old 08-22-2021, 04:38 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
higher lift or longer duration would both mean more material on the cam, not less, so a grinders not going to help. i don't think one can just add material to a cam, as it's a hardened surface.
i think you're going to need new cams for the purpose.
Old 08-22-2021, 10:42 PM   #3
Turdinator
Señor Member
Turdinator's Avatar
They can grind them such that the base circle is smaller so that the relative lift is greater. You the use bigger shims under the followers to make up the difference. I don't know if it works for our engines specifically but its not uncommon in older motors. You can also weld on extra material to the lobes and grind them to a spec. You get better geometry this way but of course if its not done well you have risks to the camshaft integrity.
@Rabrooks no one really fucks with cams on these motors as going FI is better bang for the buck. Personally I'd love to throw some cams on an FA20 and see what happens but I just don't have that kind of disposable cash at the moment. If you do I say go for it.
1974 TA22 Celica
2013 86 GT
Old 08-24-2021, 09:15 PM   #4
Rabrooks
Rabrooks's Avatar
Well, I have the spare cams. I believe what you say about welding on hardened surface and grinding to a new shape or height. I think its time to contact a few cam grinders to get their thoughts. I want to stay NA. So I need to benefit from more inlet via higher valve opening.
New cam grind? Rabrooks Engine, Exhaust, Transmission 0 08-22-2021 01:14 PM
4th to 5th gear grind. allowe Engine, Exhaust, Transmission 23 07-26-2017 02:53 PM
Shifter Grind... Stang70Fastback Issues | Warranty | Recalls / TSB 30 01-06-2017 02:09 PM
4th gear grind aaguirre123 Engine, Exhaust, Transmission 8 08-03-2015 04:58 PM
3rd gear grind Mo707 Scion FR-S / Toyota 86 GT86 General Forum 18 07-29-2012 07:37 PM
