Old 08-22-2021, 01:14 PM   #1
Rabrooks
Rabrooks's Avatar
Drives: 2020 Subaru BRZ
New cam grind?
I have a spare set of cams. Does anyone if a cam grinder can create a higher lift cam from my stock set? I want to port the heads but I want to be able to take advantage of the better flow with either a higher lift or a longer duration.
Can someone share where I can fi d out the cam specs static and also at full vvt advance.
Thanks
Rabrooks is offline   Reply With Quote
2nd gear grind mramones Scion FR-S / Toyota 86 GT86 General Forum 40 02-21-2020 09:19 PM
5th gear grind Hugo Issues | Warranty | Recalls / TSB 7 06-08-2016 08:33 AM
5th and 6th gear grind... Basket Case Engine, Exhaust, Transmission 7 02-11-2015 08:53 PM
Grind Into 5th Gear Since885 Engine, Exhaust, Transmission 8 01-18-2015 05:47 PM
2nd gear grind (yup another one) SmartedPanda Issues | Warranty | Recalls / TSB 17 09-10-2014 04:02 PM
